96 Beretta Project
  • Originally posted by 3400-95-Modified View Post
    I don't have anything against ABS nor do I think it takes any control away from me regarding driving so um no it's staying....
    I didn't think you'd let him off so easy .
    Hopefully you can get the coils to sit under the cowl hood.. Glad to see that you were able to get some traction and hopefully things will continue to go well!
    • When your talking about your wheel spin issues, I seem to understand you have them somewhat under controll, but have you thought about air shocks or air bags in the rear, so when you hit the track you can air them up and have the car sit racked, pushing more weight on the front wheels?
      • Thought about it, yes, done it, no... I just did full Koni suspension which did help a lot in weight transfer since I can set the shocks to max stiff on rebound and they wont allow the font to lift so much. This also added to the overall handling of the car and I think compliment it better than air shocks in the rear. I may some day stuff some bags in the rear if needed but right now a set of rubber spring helpers and the Koni's seem to be helping a lot.
        Oh and for Christmas...
        I love my wife...
        Add a second Nitrous bottle to this as well.
        The guy at Dyno Tune was blown away that she was able to figure out what I needed and buy it. He said even his wife wouldn't have been able to do that.
        For those who don't know... Its a full direct port plumbing kit with a tube bender and all, as well as a Progressive Nitrous controller with integrated WOT switch, no more damn micro-switch on my pedal that screws up all the time.
        • You need the football traction mod...
          • Originally posted by ForcedFirebird View Post
            This post is worthless without pics.... LOL
            I can only guess football stuffed in the middle of the spring as a bump stop.
              No, air it up at the track and your car won't squat in the rear and lose traction as easy. It's popular mod for the Cobalt to get better 60's.
              • That would be a football stuffed in the spring replacing what used to be a bump stop... basically a poor man's air bag setup.
                • I'm thinking of just doing these, http://www.rockauto.com/catalog/more...110&cc=1028887 But I hate the idea of giving up my Koni adjustable shocks back there... Maybe I'll put them in only when I go to the track.
                  • It's more like an air bag than bump stop. Bump stop just stops the spring/shock from compressing more than it should, the football mod will keep the spring from compressing as much (about the same as increasing spring rates). Nice thing about the football is you drive to the track with it deflated and your car will ride normal, then inflate it at the track.
                    I always wanted to try bolting a solid bar in place of the rear shocks on a FWD car and see how that helps the launch, just wouldn't want to drive it around like that haha.
                    EDIt: There was a video on youtube showing the installation and effects from different pressures in the football, but I can't find it anymore
                    • well yeah I know its not like a bumpstop at that point, but its replacing whats there... Currently a football will not fit in my springs... I think I have about 2" of space between the bump stop and where it hits. Hence why i said I would be removing mine to fit that mod in there. I don't think I would even have the space if i jacked up the rear to fit it. I currently have spring helpers, the solid rubber insulator between coils and that has helped quite a bit... I'm tempted to just get a second set of them and put the those in at the track to further help any squat.
                      Solid bar was one of my plans and may still be high on the list since it's very easy to swap a set of shocks at the track.
                      • Well had some fun and learning last night... As noted in my other fun thread of digging a trench to my garage, I also picked up a cheap plasma/MMA/Tig welder to play with. Seeing how I don't have the volume as any shop would I just couldn't justify spending thousands on a TIG that I would use only from time to time. All I can say is well it works and works great for what it is. DEFINITELY a learning curve going from MIG to this. I'll be cutting up my old air tank some more and practicing on it as much as I can.
                        I have to say the hardest thing for me is the fact that I don't have a foot pedal, It's a hand trigger so it's a bit harder to old the torch in a way I can easily manipulate it as well as push the trigger on. Looking at getting a foot pedal for it but I just don't want to spend the money quite yet. It is amazing though at how much less current you need to do something with a TIG vs a MIG welder... and its nice to just change filler rods when going from stainless to mild and not having to swap tanks from a 75/25 mix to a TRI mix as well as swapping spools of wire... It's nice that the 100% argon works for both.
                        • Pics of welds?
                          • Originally posted by bob442 View Post
                            Pics of welds?
                            Still learning, but this is one I did last night after having a paint gun fall on my head from the top of the shelf I was moving and proceed to bleed all over the bathroom... LOL
                            I have a foot pedal coming this upcoming week so I'll have better control vs just an on/off switch and constant current level. I also have larger electrodes on the way and a smaller filler, right now I'm completely backwards, welding with a 1/16 tungsten and 3/32 rod... This is 303 stainless with 309L filler rod.
                            Thats the first plate to plate fillet weld I've done with the setup so far so I have to say not bad for my first time as well as having way to large of a filler rod.
                            • not bad for a rookie
                              i cant wait til tax season to even buy a welder ill be able to do more and run a 220 out to the garage
                              • I ran air helper bags in my Z24, they did work but i always managed to melt the air lines.. lol
                                I've still got them around somewhere I think. but the kit wasn't too expensive.
                                I always wanted to put limiting straps on the front end, was afraid of how the car would react at high speeds though.
