Trying to keep it to only what's necessary, I am hoping to drive this car to the Denver meet this year so I don't want to go crazy and create a problem somewhere. I was going to pull the heads and change the gaskets but they haven't given me a single issue so I think I will just clean everything up, install the conversion gasket set I ordered, new Valve cover gaskets and possibly try to drill holes for the lower intake 3500 rubber gaskets some how... Or cut off the tabs on one set of them and see if they will work that way. Also I bought some cam bearings as noted so those are getting swapped out. But that's really about it. Everything else looks really good.
any suggestion or recommendation on where to position the oil holes on the cam bearings during install? This recent set I think I put at around 4-5O'clock since I think that's where the stock ones were orientated.
