You definatly need to replace that flexable piping you have.... I bet it blows up like a balloon under boost and would be supprised it doesnt pop. and i would also hook the BOV to a vac line on the engine. you need vac and boost. the FMU and WG only need the boost.
as for the check valve on the trans. i have nothing different then stock you shouldn't have any problems w/o the valve. ive been running mine for about 1-2 years that way and nothing feels funny with my trans. my cars idles a little over 1000 rpms. keep in mind you car has to suck harder to get air threw all that piping so it will idle up a little to get the extra suction.
boost through your MAF just like you are doing. that is how everyone does it. your MAP will max out when you make pos. pressure (boost) hence the reason its a 1 bar (14.5 HG's to 0 HG's. 2 bar=14.5hg to 14.5psi and our cars cannot run a 2 bar) so you need your maf to do your fuel adjustments from there. also if you suck threw your maf and have a BOV that does not recurculate you will have stalling issues when your bov opens. your doing it right there. I would also replace the maf-to-TB pipe with a 3" pipe. your slowing the velocity of that air coming in by reducing it after the maf. here is mine again...
S
S
