Bolted on a few more things
That's a few more things bolted on. Power steering pump and bracket, under drive crank pulley with trigger wheel, clocked the turbo so the drain faces down haha.
The FWD water pump pulley I noticed is larger than the RWD pulley. Both bolt on and are the correct depth. I'm wondering if its a good idea to put on the FWD pulley and turn the WP a little slower. Any ideas?
Any reason the oil filter adapter can't be bolted on like this? It clears the starter I'm just not sure it will clear the frame.
