good to know!
89 Firebird Turbo 3500 Build
don't lie, you just don't feel like driving it. we all know V6's can't break ring gears.
Originally posted by caffeine View PostRing gear carnage
Haven't taken the diff out yet to check for further damage.
Judging from the noise coming from the rear end I went from one broken tooth to 3+ within probably 3-5 km of very gentle driving. I'm just glad I was still able to drive it home haha.
Fiero feels painfully slow now.... And the suspension is just awful in comparison.
'86 Fiero, 3500, 4-speed
yeah, I used to rock a turd gen, it was a fun car, parts of me wish I still had it, as far as I can remember, it handled better then the Fiero, but neither really had enough power for it to make an appreciable difference in the fun factor..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I think the fiero could handle great but there's only a few options for it. I have KYBs on the front and some stock-replacement struts on the rear and I actually find the KYBs softer than the stock replacements.
Firebird has the factory 36mm front/24mm rear sway bar package, along with quick ratio steering box, solid bushings everywhere, tokico illumina struts and QA-1 shocks. Very tight handling car but not harsh either. It actually surprised me how smooth it rides on bumpy roads.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
eventually, I would like to make a custom cradle for mine, and redo the rear suspension entirely, then hit the front. I need to really start digging into suspension theory before I start tackling anything that extensive though..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Just thought I'd update here since it's been a while. Still DDing this with the 3.23 10-bolt, haven't been able to get to a track yet (been rained out every time so far). Finished installing the STI seats with some 1/4" steel for more strength than my original "brackets". Also moved them about 1" away from the doors and now they sit mostly like factory.
Tune is almost to the point of me being satisfied enough to burn a chip.
Also ordered an OBX 3" cat-back with quad 4" tips that arrived this morning. Hopefully will have it installed on Wednesday. The muffler may be a bit of a restriction but I really have no idea yet. The turbo outlet is only 80mm so 3" back should be fine.
Also was looking at T56 gearing tonight and I was actually surprised that when you put T56 gearing with a 4.11 rear gear ratio, the final gearing is almost identical to the Getrag v160 for 1-5th. 6th is longer in the T56 by quite a bit.
Last edited by caffeine; 05-28-2013, 02:24 AM.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
Hi Blair, I shipped that prop. valve spring sometime last week. text me your # again when u have a moment, I just got a new phone.
Have a good one.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
Prop valve spring received!
Finally got some runs in at the 1/16th mile (384' actually). Mixed results, but one half decent run. Hardest part was trying to figure out the best way to launch. My 2nd to last run was the best and I launched with the 2-step at 2400 rpm and had just a bit of wheelspin off the line.
Last run I did a bigger burnout with the 2-step still at 2400 and it hooked and stalled right away. I'm thinking I just need to get my burnouts right and then raise the 2-step to 2800 or so. A slight amount of wheelspin seems to be what I want.
Then again the rear gears are probably holding me back as well. Hooking at launch with no wheelspin might be ok if I had 4.11s, but with 3.23s it just stalls. I'm dumping the clutch of course .
Anyways the numbers on my best run were
2.251 60-ft.
5.871 330-ft.
6.384 384-ft. @ 70 MPH
Speed seems pretty good IMO but launch is really holding me back right now. I'm just shifting into 2nd at about 3/4 down the track.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
why in the world is the track so short?
I thought you'd be launching that thing like 4000.
I have my 2 step set to 3400 now, it builds good boost and stalls the converter perfect. cant wait to hit the track, maybe this weekend !11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
