89 Firebird Turbo 3500 Build
  • Do the IRS swap!
    Go for a vette dana 40! They are easy to narrow or shorten without killing geometry. Getting it centered is the hardest part of the build, but once its dialed in, the rest is easy!
    • Go with a 3.9 for the next motor if you can find em cheap. Makes quite a bit more then a 3500. Sounds like you're having fun.
      • Originally posted by Driver_10 View Post
        Do the IRS swap!
        The reason I would go for 300zx rear setup is availability (don't see many vette setups around here), and cost; people practically give them away. My buddy I'm renting the shop with also happens to have a 1.5-way LSD lying around that would fit it. The 300zx setup comes with a nice subframe to locate all the suspension, so it's just 4 mounting bolts plus shocks/coilovers; 6 mounting locations in total to fab up. The vette IRS just seems much more complicated to set up.
        '86 Fiero, 3500, 4-speed
        • Originally posted by Mars View Post
          Been considering going 3900 but only if I can figure out a way to use the FWD accessories, since I don't want to spend the money on a CNC timing cover. Also I'm unsure what exactly to do about the cam if the stock timing cover is retained.
          • Went over to Vancouver and picked up a fresh pair of 3500s for $500.
            So far plans for this year are:
            Better rear end gearing
            ARP head studs (already have them)
            Air-Water intercooler
            Weight loss
            75mm TB
            Install my LS1 front brakes
            Possibly QA1 struts up front to match the rear
            Also looking at installing a Jeep Grand Cherokee steering box to get more angle and Racecraft drop spindles
            • I need to pick up some 3500's for myself... I have too many 3100's and 3400's lying around.
              • New motors just about to go in
                New clutch. Head studs, picked up some V-bad wastegates, gonna replace the flex section in the headers as well (seen better days).
                • What's that LS & T56 going into?
                  • 240sx
                    • Went to the track this weekend. Had a great time. I was only running wastegate pressure @ 11 psi but ran a 12.3 @ 110 and I was pretty happy with that considering it's my first good set of runs with the car. I know it has more in it and I'm still only at 3.73 gears so I can get more out of it with 4.11s as well.
                      I was gonna install a boost controller on it and take it to 14 psi but we were trying to get my friends Subaru STI/EG33 swap going in time and didn't quite make it.
                      Anyways, here's some pics of our trip and the fleet
                      • Looking good man. Dang i got some competition trying to keep up with your car... nice work.
                        1/4 mile best 11.59@119mph
                        1/8 mile best 7.47@94.9Mph
                        • Any updates on this build?
                          14.96@91.47 in the 1/4
                          9.63@74.36 in the 1/8th
                          • Looking for Gm fiero intake
                            Sent from my MotoE2(4G-LTE) using Tapatalk
                            • Wat
                              '86 Grand National
