looking for 3500 cam regrind
  • #61
    mine are from a Syclone/Typhoon turbo 4.3.. they're 32# @ 43PSI and 36# @ 55PSI
    Yes, you can run the newer injectors. If you can find a set from a L67 (3800 S/C) they are 36#@ 55PSI.. I'd run the older 43PSI FPR so they'll be around 32#. It's an easy change if you start to max them out.
    you'll also need to snag a fuel rail from a 3100 or 3400.
    Actually its closer to 38 lbs/hr @ 55 PSI when using ZZP's spec(34.28 lbs/hr @ 45 psi). But either way it should still be plenty of fuel for a 1280 or 1617 cam with a little room left over for some nitrous help.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
    • #62
      Sappy, the 1529 cam is similar to Superdaves but with more lift. Can it be ground with slightly less lift? Maybe about .58?
      • #63
        I don't need a new cam
        I'm confused.. the 1386 has a 106ICL and 110 LSA.. the 1617 has a 107 ICL and 111 LSA.
        Personally if you are going for all out power then the 1386 should scream, idle like hell and work out very well with the ported heads and headers.
        However if you plan on driving it every day the 1280 or 1617 will be a better choice. The difference in overall power is hardly noticable. It's still going to lope with either cam.. If you really want it to lope then just advance the spark timing at idle to around 30 degrees..
        funny on the advance idle...
        1280 sounds good....well see how long it takes for me to change my mind again
        2012 Chevy Sonic Turbo 6spd
        • #64
          You can change the LSA and ICL but not the lift or duration.
          • #65
            which is better for the 3500, more lift or more duration? im stuck between 1617 and 1280. they look very close...whats the pwer look like on these?
            • #66
              To reduce the 1529 lift, are 1.50 or 1.55 lifters available.
              • #67
                I don't know about you guys, but I like my cam for street use (see sig).
                SpudFiles
                Theopia
                Enjoy life online.
                • #68
                  1.52 crane gold race rockers are available. Not cheap to go that route though.
                  • #69
                    i just tried to fit my old injectors on the 3500 rail and lim, no where close to what it needs to be. any advice on how to make it fit or am i just going to have to get different injectors?
                    • #70
                      Use 3100/3400 rail.
