Underdrive pulley with damper for 3400
  • #31
    Im working as fast as I can. If anyone has a spare piston or 2 from a 3400/3500 etc let me know. This isnt even an official teaser though....teasers normally have pics or a vid. sorry. I will def get pics as soon as i get anything in, but i dont know eta yet.
    • #32
      I have a 3400 piston and forced has a 3500 piston I bet:P
      • #33
        ok. well thats another piece to the puzzle
        • #34
          I have a 3500 piston if he doesn't.
          • #35
            Ill put my ffp udp up for sale as soon as I see pics.
            In other words i'm 100% interested.
            BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
            • #36
              Steel... will they still be lighter than the stock ones? I'm assuming it would be due to just size difference alone, but going from the cast to aluminum is a big jump, I can't imagine you can obtain the same difference with steel.
              • #37
                Most of them are steel, and an SFI would def have to be steel. But even with being being underdriven in steel, they are normally lighter than stock in a regular ratio, and underdriven will be that much less mass to move
                • #38
                  interest here too!
                  Andy
                  fastest 1/8: 10.19@ 67.17
                  fastest 1/4: 16.16@ 82.70
                  • #39
                    Originally posted by torq455 View Post
                    interest here too!
                    new guy here, quoted for effect.
                    I just got another engine put in i figure i can start trying to mod it.
                    • #40
                      fwiw this one seems to be the easiest mod worth the most power without compromising drivability if you go with the 10%....IF they look at making a 25% i would either get a higher outpul alt or go with an overdriven alt pulley and if possible a waterpump pulley as well. on some autos with alot of stereo equip, it can be a drain sometimes on the cooling and charging system. for normal DDs i would go 10% all the way, for a more race inspired car 25% would be most effective.
                      • #41
                        that's why 18% is perfect. simply raise the idle ~100 rpm, and that counter acts the low alt output at idle.
                        Andy
                        • #42
                          You should work for powerbond.
                          • #43
                            ohhh i wish!!!!
                            Andy
                            • #44
                              too bad they are in australia. hah. well they are either 25 or 10 % take it or leave it. personally ill take a 10%. good enough for me...along with the ARP Crank Bolt....
                              • #45
                                im not sure what i would want. i do have an amp, 800 peak and 400rms... but i want every little bit of power i can get lol
