Underdrive pulley with damper for 3400
  • Underdrive pulley with damper for 3400
    Powerbond is going to be making the SFI Race underdrive pulley with 24x reluctor built in. Price range estimated $200. If you are interested, please post up. This is the same company that makes are stock units, so durability and quality are not an issue
    Interesting. Would definitely be on my list of things, once I get back to working on these engines...
      Sounds like something worthy of my fantastic 3400 engine. I'm intersted.
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        I might be in for one as well, pending actual specs.
          They make 10% and 25% UD pulleys but I don't know if both would be available. If you have a preference go ahead and post away.
            A little info on Powerbond... http://www.precisionparts.com.au/Pag.../powerbond.htm
              I'm definately interested. Would these be in steel or aluminum?? (Not sure if an aluminum balanced UDP can be made)..
                You know I'm interested.
                Your local OBDII moderator
                2000 Grand Am GT w/ WOT parts
                  Id be down.
                  COP: you were going 96 in a 55mph zone. your plates on upside down, u failed to signal, do you know why i pulled you over?
                  ME: because of the for sale sign, u wanted to see this fine piece of automotive history up close and personal?
                  COP: clever.. clever.. very funny. now take off while im laughing before i ticket you. get outta here.
                    Would love to see this happen.
                      GODDAMNIT! I just used a factory pulley to have my bottom end balanced!
                      Matt
                        I thought our cranks were internally balanced already so when you balance a lower end all your doing is matching all the rod/piston assy's to the same weight and such and then you would just use a balanced pulley... in other words I did not think we had externally balanced motors.
                          We don't have externally balanced motors. Nothing to worry about.
                            Thats what I thought, so having your lower end balanced with the stock dampener is either the wrong way, or it's not even being used in the balancing process.
                              So I could conceivably put one of these SFI Race serpentine balancers on my balanced 3400 bottom end and not have any issues.....right?
                              If so, very interested.
                              Matt
