Anybody Doing Anything With The LZ9 Engine?
  • #31
    The input shaft on the tranny broke, I believe.
    • #32
      Ohhhh ok. Lol.
      Sent from my iPhone using Tapatalk
      • #33
        Yeah input shaft broke. Replaced that with a hardened one then the clutch disc's went bare and the material trashed up the valve body. So now it sits while I work on a replacement.
        • #34
          284 swap?
          Current:
          \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
          \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
          \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
          Gone, mostly forgotten:
          \'90 Pontiac 6000 SE AWD: slow but invisible
          • #35
            Originally posted by Will'sFiero View Post
            284 swap?
            4T80E
            • #36
              There's a guy running 10s in a cavalier with a built 4t65E. Might be worth looking in to.
              '86 Fiero, 3500, 4-speed
              • #37
                +1 for the 284 swap... lmao
                • #38
                  I know the 65E can be built to handle the power, right now I have less then 500 into the 80E with a high stall converter, 3.71 gearing, and updated valve body. So I'm still way under the 2k price of a built trans.
                  • #39
                    I think I've read somewhere that the 80 isn't easily controlled. Do you already have a trans controller figured out?
                    • #40
                      from a control standpoint, it has the exact number and type of sensors as a 4T65.... i would say that if there are any control problems, they either aren't 4T80 specific or base calibrations aren't anywhere where they need to be.
                      • #41
                        hi BearBear; is there a link where I can see what you've done? Just picked up a crate LZ9 to put into my 308/fiero project.... Interested in doing 'something' extra but it will depend on long term reliability rather than total (ie momentary) power output.
                        Likely will pair it with a G6 6 spd manual.
                        thx
                        GP
                        • #42
                          I'm thinking about putting a 3.9 and t5 in my miata. I tune my lsx stuff with hptuners. I want to go NA.
                          From what I gather 3.9 + 3.5 intake ported + cam + non phasing timing set/springs should have me somewhat close to 275+hp? A 3.9 bolts to a t5 correct?
                          • #43
                            Sounds about right and yes it will bolt to a T5
                            • #44
                              Ha I had just emailed myself your reply to someone else with the information in the swap section. Thanks for the info!!
                              Where is everyone getting parts for these things? Wot-tech the only place?
                              • #45
                                Wot-tech is the best place I know of.
