  • ericjon262
    replied
    got the engine back, finished the final assembly, installed the flywheel and clutch, installed a new HTOB, bled the master, bled the line, started bleeding the HTOB, and apparently, it's defective. there's a nice little puddle of hydraulic fluid dripping out from the bellhousing. never got a pedal at all... my machinist did great job on the engine, but he took way to damn long. if I had the engine back, even last week, I would have had time to deal with issues like this.
    oh well, life happens. I'll get a new clutch (clutchnet stage 4) and HTOB(GM) on order before I leave tomorrow, and when I get back, I'll fix it.
    it'll take a little longer then planned, but I'll make it happen still....
  • Guest
    Guest replied
    anything new? running yet?
  • ericjon262
    replied
    Originally posted by bigcheese View Post
    any updates?
    just getting all the little odds and ends tied up, not really a whole lot worth posting.
  • Guest
    Guest replied
    any updates?
  • TGP37
    replied
    Cool, you need many hours of log data before you go on sea duty. To have something to analyze and refine the tune. Believe me, you can go as far as the mind allows there, street tuning. The trick is finding how to filter out data you don't need per formula/table/etc.
    Once I got about 2+ million rows of data (5 rows per second) (each row had all the engine data for that moment) LOTS OF DATA compiled into a massive excel document, the data crunching began. As an example you can see what I mean by analyzing......here is a collection of data I have so far...mostly relevant to my build only. But some things are usable, like max torque per AFR, Spark, etc. as a base point of reference. Though I only suggest getting ideas for analysis and charting your own data.
    When you come back to dry land, you'll have a nice refined tune. Even if you get the dyno to tune it, you can always refine with lots of road data.
    link
  • ericjon262
    replied
    exhaust is 99% complete, just need to put the slashcut in, and a flex coupling. should have pics tomorrow.
    LC1 is mounted, and the wires routed, still needs to be wired up, but for the most part it's done.
  • TGP37
    replied
    Bigger blocks need twins at some point or the lag will start to become frustrating for a city driver. Another score for the 60V6!
  • ericjon262
    replied
    yeah, esp with a port and polish and cam swap. there is a guy on PFF with a TT N* though, so it is possible. I'd do a big single before twins anyday though.
    replied
    northstar/F40 would probably be more than enough fun though.
    replied
    i think the northstar itself takes up enough room, let alone 1 turbo, let alone 2.... give it some air/air intercooling and you'll have to disassemble everything just to check the oil.
  • ericjon262
    replied
    twin turbo northstar fiero as a beater?
    lol, you're adding a few interesting ideas in there, but I was thinking just N* maybe a 6 speed to though...
    replied
  • ericjon262
    replied
    "hopefully for the last time" .....lol
    you have no idea... everything on the car has been done at least twice... some things, like the wiring harness, have been done 3 or 4 times...
    it got to the point today, where I almost said screw it(and many other words...) and made a dual exhaust and got rid of the turbo. this thing has been the biggest packaging nightmare on the planet...
    I need to go and refill the gas in the welder, hopefully tomorrow, the exhaust will be 100% done and I can move on to some of the other parts of the build.
    when I get a chance, I plan to pick up a beater Fiero and redo the whole kit. (then swap a N* into the beater...shhhh don't tell anyone....)
  • Nick-G
    replied
    What prevents you using the exhaust? I have mine 1 foot ahead of the catalytic converter and it draws a nice vacuum in the upper RPM.
    (I ask under the guise it may help out Eric's build, being this is his thread)
    I just didn't leave myself enough room. I have a cut-out right after the downpipe and space before the cut-out is limited.
  • TGP37
    replied
