Coming Soon: Higher Ratio Rockers
  • Originally posted by gectek View Post
    i have an update!
    Worst Post Ever!!!
    • suspense is great....ill wait a little bit longer...heh
      • Does it have anything to do with Scorpion taking over some of Crane's parts, now that they are no more??
        • NO, but since you said that, I also just now found out that Scorpion will be making valves, springs, lifters, and a few other valvetrain products as well as rockers. They just started to expand. Ill give more info when i get a few more emails from scorp.
            i have an update!
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
            • solid rollers and a way to adapt their rockers to adjustable. get r done.
              • Looks like 2 months and these things will be nearly ready to go into all our vehicles. They are waiting on final design and material now.
                • nice sounds good. 2 months is cool and at least these are an easy swap
                  99 Grand Am GT
                  1357 cam 227 233 .050 dur
                  515 515 lift 112 lsa
                  • I can wait two months... Now I have time to save up for it
                    • Originally posted by SappySE107 View Post
                      I still think 1.8 intake 1.7 exhaust would be ideal for stock cams. Even a straight 1.8 set but I don't think the exhaust needs 1.8, especially on a 3500.
                      Thanx Ben!
                      Put me down for a 1.8/1.7 set the minute they are available.
                      Much appreciated!
                      • Ben if you can do a split set for Eric, I'll take the other half of his order to do the same thing... I think 1.8/1.7 would work for me or is 1.7 all around a better setup...
                        1.7 ratio lifts, 549/603
                        1.7E 1.8I lifts 581/603
                        1.8 ratio lifts 581/639
                        You tell me what would be the best... I'm running the Comp springs from your store and stock valve seals just a FYI.
                          Good to hear. Keep it coming John.
                          • Heck yeah! Ben, you still think on a 3400 with the 3500 UIM, 65mm TB, better exhaust, and headers with a tune, it's still better to go with the 1.8/1.7?
                            Andy
                            fastest 1/8: 10.19@ 67.17
                            fastest 1/4: 16.16@ 82.70
                            • Just want to get in on this,I will need 1:9 ratio I suppose as with my cam I lost lift and gained a little duration,These rockers should surely add some power eh?
                              • if theres another person that wants to do the split 1.7 1.8 set then im good otherwise ill go 1.7
                                99 Grand Am GT
