building destroked 3400
  • #76
    it's a bosch 305cc/min injector from an audi s2(turbocharged 5 banger).
    it has what seems to appear to be a needle type
    of nozzle beneath the hat.
    btw isaac it's a 96 transport manifold.
    nothing's impossible-it's just a mindset
    • #77
      Those caps look like my old 2.8 injectors before the caps fell off and injectors went fubar.
      00 Grand Prix GTP Daytona
      • #78
        hhmm question , whats the max bore on a 3400 engine A block?
        • #79
          max. rebore is about .040 some will go to .060
          • #80
            Okies thankss
            • #81
              intercooler arrived
              here is the ebay IC(china stuff).
              I plan on mounting that one in the rear wheelarch(driver side)of the fiero.
              this way would isolate the intercooler from the heat in the
              enginecompartement.
              another option would be the trunk compartement of the fiero..
              but since I wanna remove most af the wall between trunk and
              eng.comppartement it would warm up cause it would be in the
              same compatement(pretty much)
              for cooling the charge I bought a motorbike cooler from a 1989zxr
              kawasaki(ninja).this is pretty much a flat radiator of a modest size
              compaired to the coolers from small cars.
              I plan on installing that one in the nose.
              • #82
                Those injectors should work well, i'm at about 75% Duty cycle on my 36lb/hr injectors (.60 lbs/minute).
                • #83
                  with the added plumbing to a cooler in the front atleast you wont need to run a res. tank for the IC but i would still add a fan and maybe even a co2 spray bar or something more closely mounted to the IC might be a good idea for track days
                  • #84
                    the radiator from the kawa has the fan on it.
                    I payed only 25$ incl.shipping for that one LOL
                    I am not sure wether I wouldn't need a reservoir/tank for the coolant.
                    I think that depends on the type of pump.
                    If I'd have the chance ..I would do it without a tank.
                    bought me some 3/4 ID oilhose for the lines.
                    that set me back about 55$ but this is way better than gardenhose.
                    now I only have to receive the pump,that one was about 50$incl.shipping.
                    and I need to get some 90 degree elbows for the couplers..
                    so in all I have a decent IC system for about 245$.
                    • #85
                      trick is to get it so its not pumping so fast that theres no cooling effect taking place with that radiator though...
                      • #86
                        that radiator is about 18-19 inches long and 9 inches wide
                        thickness is aprox. 1 inch.
                        in my opinion that's not so small.
                        I've seen people using oilcoolers that were a lot smaller..
                        and those aren't near as efficient as the watercoolers
                        my oilhose has a 3/4 inch diameter so that should work well with
                        that radiator and pump,the large ID will keep the pressure a bit down.
                        • #87
                          I might even consider a small extra radiator just below the fuellfillercap.
                          I made some sort of integrated rocker panels for the fiero so that scoop
                          is always convenient for a small cooler or perhaps an oilcooler...
                          • #88
                            I just saw an aeroquip that Driver_10 is using on his 3400 RWD Camaro. It uses coolant to control the oil temp, so the oil is always the same temp as the coolant. Pretty slick and it wasn't very expensive. You just need to re-route your radiator hoses to it.
                            • #89
                              well..volkswagen has been doing this for 15 years or so.
                              it's nothing new......
                              it also helps the oil warm up faster.
                              • #90
                                and caddys new 2.8/3.2 dohc uses it as well....
                                any more info on the adaptation of the m90?
                                2012 Chevy Sonic Turbo 6spd
