well..made the discision to build it !
the 3000 engine based on the 1997-3400 block and ported heads with only
16 miles on them ! ! !
will be using a 89 '2.8L-v6 beretta crank,this way I can use the
original crank sensor for the ignition build up.
rods will be from scat for a 327 engine/forged of course
I will be using clevite 77 main and rod bearings in standard size(max.strength).
for now it looks like i am going with the stock 3400 oilpump)seems sufficient).
stock camshaft and pushrods will have to do for now.
thinking about some LS6 valve springs since it will be blown
by a m90 supercharger.
and eventually a set of home made headers with 1.75 primairies.
looking for 250hp at the crank to start with.
with aprox.10-12 psi
and the will to rev to 6500/7000rpmīs
should be possible right ?
Iīll post some pics later guys
