Still trying to locate oil leak...
  • #16
    By the way i finally found a use for my otherwise useless scrubs left over from nursing school!!!
    • #17
      Is my #1 the number one in the diagram?
      • #18
        Ok I know it looks important but I have no idea where it came from!
        • #19
          Should the intake manifold be dripping so much (oil?)?
          • #20
            Can anyone give me a lift to work tomorrow?
            • #21
              • #22
                • #23
                  Nope it's the only other bolt visible in the first picture. That holds down that slightly V-shaped bracket that holds the oil pump drive in place (aluminum circular thing on top of oil pump drive is visible clearly in first picture). Once you remove the bolt and the hold-down V-shaped bracket, you will probably have to use a screwdriver or pry bar to pry the oil pump drive up and out of the hole. Then the o-ring will be clearly visible.
                  The bolt that you circled doesn't appear to be a major (if at all) oil leak, just based on the fact that nothing has really run down from that location.
                  '86 Fiero, 3500, 4-speed
                  • #24
                    Looks like it could be a weather-proof rubber piece from a wiring connector.
                    • #25
                      • #26
                        Once again, Thank you! I really appreciate all your feedback.
                        • #27
                          your day off is your day off...rain or shine!
                          • #28
                            Does this o ring look like the culprit?
                            • #29
                              I also noticed that rubbery gasket ended right around where the oil pump drive is located. Does that look like it's ending short of where it's supposed to? Any chance the oil is coming from there?
                              • #30
                                I'd bet money it's for the TPS connector. I have seen that one many times.
                                Can't remember for sure on the gasket. Swear that they are that short even new.
                                Thought you could also use the small block Chevy distributor gasket to help seal it where it touches the block. Or is that just for the 3100/3400? I was thinking the 60 degree drives are the same.
                                Grand Prix trans with 3.33FDR
