Adjustable Modulator 4T60E
  • #61
    You need to shim your accumulators if you want chirping power shifts...
    • #62
      Right. This mod just seems to freshen up the trans and make it feel newer and less sloppy. But nothing crazy where other people riding would comment on it.
      • #63
        Well it's perfectly acceptable right now
        When I get around to it I'll try and shim the accumulators when I change out the fluid for the Dex-VI and put in my drain plug.
        • #64
          You can do that easily with it in the car??
          • #65
            No no no, this is when the engine is out and being swapped for the 3500 (or at least attempted to be)
            • #66
              Ahh ok
              • #67
                Originally posted by PCGUY112887 View Post
                Can you even get VI anywhere aside from the dealer?
                Even then, it's probably $10+/quart.
                Red Line makes a Dexron VI compatible ATF at $14/qt.
                1995 Grand Am SE
                • #68
                  Pennzoil sells it for around $7/qt
                  Brian
                  3400 SFI V6, 4T60e
                  • #69
                    i installed one last week..now i hit the limiter between 1-2 WOT gotta work on that later
                    Best 1/4mile ET - 12.9
                    Best 1/4mile MPH - 111
                    1997 Ford Ranger Splash
                    Daily Driver
                    • #70
                      Loner, funny, I was hitting the limiter on 1-2 shift too and THEN I installed it. Seems to only do it on this one on-ramp. Everywhere else it shifts at 5500, but this one it shifts at like 6xxx and bounces off the rev limiter once before it shifts...
                      • #71
                        I'll chime in on this one too.
                        After a more extensive drive with the modulator, it would seem that it holds the gears longer when under moderate acceleration (could be my imagination I suppose). While I haven't yet done a good WOT run, it wouldn't surprise me if I hit the limiter.
                        But I MAY need to turn it down, as it shifts much more aggressively than previously thought. The 1-2 is just crap-your-pants firm as opposed to before. Not that it bothers me mind you but I don't wanna max out the pump either.
                        • #72
                          on the 4t60e, the modulator doesnt controll shift timing at all, thats all done by the shift solonoids and pcm. all the modulator does is controll the pressure.
                          • #73
                            Hmm.....well I dunno whats happening then
                            I was under the impression that if the trans was seeing lower vacuum at the modulator, it would assume there is more throttle being applied, and thus holding the gears longer (like cruising 35mph and getting on it to pass someone)
                            Just proves how little I know about transmissions .God help me with shimming those accumulators
