Supercharged 3.1 in a Sonoma
  • #31
    Thanks! I'm interested to see how much power it makes.
    Looks like you have a lot of space available in there. Have you decided on a BOV system yet? If running no MAF sensor, it will be much easier to deal with.
    • #32
      We're using a Greddy BOV that was recently replaced on my friends Audi 1.8T. Nothing wrong with it except it sounds like dog farts .
      '86 Fiero, 3500, 4-speed
      • #33
        That sounds like a small 2 stroke dirt bike lol
        2000 Chevrolet Malibu LS (LX9-F23 swap soon!) Slowly acquiring parts!
        • #34
          Cant wait to see what she does on the road.
          • #35
            I have been thinking of putting a 3400 in my 4X4 S10 but figured the starter wouldn't clear as it is on the wrong side. You obviously had no starter clearance issues?
            '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
            • #36
              The bellhousing was trimmed for the starter and there was a dimple put in the crossmember for it as well; the 3400 has a much smaller starter on it though and I doubt it would need the dimple.
              • #37
                Actually if you wanted to do this without trimming the bellhousing, grab a 94-95 bellhousing/T5 from a 2.2L engine. Or a 94-95 bellhousing with a mustang t5 and swap over your s10 tailshaft.
                In any case, we took this for a rip the other night with an N/A belt and tried out 8F. Tune is actually very close already. Time to run it with the charger . The charger is still super loud at idle because the BOV is constantly open... Might need to get a bigger BOV because its like the charger is forcing air out of a tiny BOV.
                • #38
                  On to supporting mods...
                  Stock gas tank cross brace had rusted away, so two new ones went on
                  Spare 3rd-gen F-body sway bar installed (from a rear end I bought)
                  Homemade traction bars ($60 in materials). Also, 3" lowering blocks
                  Also got some free 3" lowering springs for the front
                  Air filter for the charger
                  And a few more of the truck
                  As far as driveability goes, $8F is great so far with some minor tweaks. It's hit low boost already but some issues with our makeshift couplers has led to boost leaks preventing more. Proper couplers should be arriving any day now.
                  • #39
                    Man that came together quick.
                    Grand Prix trans with 3.33FDR
                    • #40
                      Not that it would be a great coincidence, but are you also thinking about designing your own BOV?
                      • #41
                        What do you mean? There's some sort of greddy BOV on there already.
                        Would be hilarious to put a duck call on it though lol. Just because its constantly open at idle
                        • #42
                          Well, If it turns out that it needs more venting capability.
                          In my case, I don't have one yet. It's going to need one, maybe 2 of the largest available, so I'm looking at a big investment there.
                          But I already have the internal and external standard-type bypass valves (not BOV), so it should be closed at idle.
                          I'm already on plan "C" lol
                          • #43
                            I'm in a similar situation, Gen-II RWD conversion - because those are the parts I have...
                            How does it feel with solid motor mounts?
                            • #44
                              You wouldn't even know sitting in the passengers seat. They're not harsh at all.
                              • #45
                                truck is bad ass.
