Supercharged 3.1 in a Sonoma
  • Supercharged 3.1 in a Sonoma
    So recently a friend of mine blew up the 2.5 in his 93 Sonoma. Since this is more-or-less his DD, he needed to get a new engine in as quickly as possible. A week later his brother gave him a 94 Sunbird with a rebuilt 3.1. So that's how this project came to be. Goal is to make as much reliable power as possible, maybe with a 3400 upgrade in the future. So far only around $500 has been spent.
    Old duke coming out
    Engine bay before and after
    Just a quick tremclad roller paint job
    Fiero engine to be used for a few parts, like the RWD timing cover
    2.8 was pretty sludged up. Like it had never had an oil change. This engine had only 100,000 miles on a rebuild
    Sunbird engine coming out
    Next he picked up a Supercoupe M90 for $100
    Block torn down
    RWD timing cover mocked up with intakes. No drilling out of holes or plugging extra coolant passage necessary for mounting on a gen II, and only minor grinding to the upper tab on the cover were necessary
    Heads off and ready for some mild porting
    Heads and LIM reinstalled (LIM flipped 180*), new timing chain installed also
    T5 mounted up with clearanced 2.5 bellhousing, 3.1 FWD flywheel, the old duke's clutch (still plenty of life left), and a new Sachs pressure plate
    OBX S10 2.8 headers!
    Lower holes slotted
    OBX Y-pipe mocked up
    Timing cover and water pump re-installed (I know the water pump has the wrong pulley on it right now)
    Rough drawing of planned belt routing. Going to be mounting the alternator and power steering pump in the same place as on my 3500
    So for the rest of the build here are the plans:
    Modify the crossmember for oil pan clearance (would be helpful for future 3400 swap)
    Solid motor mounts similar to the ones on my 3500
    Remote mount supercharger on the passenger's side
    Use TGP intercooler to aid in keeping IATs down
    Old Greddy BOV from his Audi A4 1.8T
    Weld a flex-pipe into the OBX Y-pipe (fitment isn't ideal anyway)
    Run $12P on a 7165 with a mostly stock wiring harness or use the stock 6647 if it's compatible (pinouts are identical to the 7165). Use a 3800sc 2-bar MAP sensor for boost.
    Stock VR6 injectors leftover from his VR6 A4 project
    Play with pulley sizes to get the right amount of boost (anyone have experience with this?)
    Obviously the gen II motor isn't ideal, but it was free and this should make boatloads of power more than the 2.5. The T5 could be a weak link but could be upgraded with a V8 WC T5 eventually. The OBX headers are actually quite nice; only snag is that the y-pipe wasn't designed very well and needs an O2 bung added. Injectors and clutch may need to be upgraded as well.
    '86 Fiero, 3500, 4-speed
    I have commend you on your tenacity. Hope it all works out !!!
      This is a cool little swap. 3.1 is an ideal truck motor.
      Are u using the FWD oil pan ? Will it clear ?
        2.8 Fiero oil pan (because that's where the timing cover came from), pretty much same size as 3.1 oil pan. Motor mounts were done today. Pics to follow.
          Flex pipe welded into Y-pipe. Fits mint now
          Engine fitment pics
          Mounts
          In the next two pictures, you can see where the crossmember was notched. Notch is slightly bigger than was necessary, but it worked well. Next it will be boxed in.
          Rough position supercharger will inhabit
          With flex pipe welded in, Y-pipe fitment is excellent. Appears to be no ground clearance issues as a bonus.
          Mounts still need to be fully welded and reinforced, but pretty much all the major stuff is taken care of. As long as the ECM and fuel lines are sorted out in time, we're gonna try to fire this up on Wednesday. So far I think we're only on week 3 so that's pretty good for time! Been doing most of the work on Wednesdays from 10 PM to Thursday 5 AM lol.
          We went with a frame notch rather than an S10 2.8 oil pan because a) it was cheaper and b) it should leave enough room to to pretty much drop in a 3400 in the future.
            ^ cool.
              Watching.
              Grand Prix trans with 3.33FDR
                Watching.
                Ditto.
                  Nice, watching as well!
                    Unfortunately didn't get much done on Wednesday, but got the sc mount mostly finished and worked on other accessory mounts as well. Wiring is mostly finished.
                    Frame notch boxed in
                    Wiring progress
                    Still have to add in a tensioner but mostly finshed
                      that belt is almost as long as a northstar timing chain.
                        maybe an idler and a tensioner, to get more belt wrap on that charger.
                          Ya that belt isn't the one we're actually using. Just something to help us align the pulleys. The tensioner should place the pulley as close to the crank pulley as possible which should wrap the charger nicely.
                            All accessory mounts have more-or-less been finalized. SC mount was re-done, and PS pump bracket is now completely custom to allow the alternator to swing down a little more.
                            Tensioner
                            PS Pump
                            SC Mount
                            Measuring belt length
                            Coil mount
                            Wiring more-or-less finished
                            Accessories all figured out!
                            Motor installed permanently
                            Didn't bother finishing it up because one of the fuel fittings didn't arrive in time. It really just needs to be put together and intake piping finished.
                              It's early and i haven't quite woken up yet... but are you sure your water pump is going to spin the correct way?
