LX9 RWD Swap - timing cover and pump specifics
    replied
    Originally posted by shapeshaver View Post
    Hey Dave, which alternator is that? I am trying to figure out where to source the right alternator and pulleys. What did your alternator come off of? And the water pump pulley? Tensioner?
    Stock alternator for a 3.1 Cavalier, water pump pulley was either a 2.8 Camaro or a 3.4, cant remember. Tensioner was pieced together with parts from mcmaster-carr.
  • shapeshaver
    replied
  • dskopek
    replied
    Here is my setup
  • caffeine
    replied
    I've found that only minimal belt contact on the water pump is necessary, but it doesn't hurt to have more either.
    replied
    Sorry, I can't get on this site from home for some reason...
    here was mine:
    TCE alternator bracket, added an extra idler for better wrap on the water pump. Turnbuckle tensioner.
    replied
    I can post pics of my belt routing later on.. worked great with only an alternator.
  • Guest
    Guest replied
    What did you do for belt routing on this project you mentioned? I have an LX9 that I want to put in an Opel which also has manual steering, so the only accessory would be the alternator.
    I haven't got to that project yet, but it's getting closer to the top of the list.
  • caffeine
    replied
    That belt routing works well for just alternator and water pump
  • Canyonero
    replied
    Just to add another option, this is how I laid out the belt routing on my Franken60, many years ago (over 10 now. ):
    I'm trying to come up with a nice belt layout for my next project, there will not be any power steering, and I hate using extra idler pulleys, but would like a belt driven water pump.
    I have a few ideas in mind, but nothing I'm overly happy with yet.
  • Guest
    Guest replied
    No, I have an L28 that I added a turbo to. I plan to swap it out soon enough though.
  • socorob
    replied
    Thanks for the photo. Do you have a GM V6 in a Z? My friend is doing a 260 right now and is supposed to be picking up an LS1 this coming week to go into it.
  • Guest
    Guest replied
  • socorob
    replied
    Thanks, that's exactly what I needed to know. Now if the crossmember guy would get back to me, then I can get a start on this.
  • caffeine
    replied
    I'm 99% sure that RWD timing covers won't bolt to the 3900. I don't think there are many parts that are interchangeable between the VVT engines and the non-VVT engines
  • socorob
    replied
    It looks like it will fit but will be VERY tight. Do you happen to know if the 3900 is the same block as the 3500 and if the 3.4 front motor cover and water pump will work on it?
