Wiring Harness LQ1 aka 3.4 TDC
  • #31
    Well, if it helps at all, my plan is to use a 2000 Impala 3400 Pcm & Harness, using ext crank trigger for the LX9 and retuning it with HPTuners.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • #32
      What kind of car are you putting that into?
      • #33
        J body
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • #34
          Cavalier? http://www.v6z24.com/registry/planethax
          • #35
            I have many different Cars lol,
            I am wanting to do something a little unique.
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • #36
              Being that you said a J body, I cannot be that far off base...
              Sunbird, Sunfire, Cavalier, Firehawk?
              • #37
                Yes a Cav,
                Wont be till April though, so have from now till then to get everything ready.
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                • #38
                  How did those with full 3500 LX9 swaps cure for the lower bucket mount that attaches in the cradle?
                  • #39
                    W bodies must not do swaps?
                    • #40
                      again, http://60degreev6.com/forum/f136/swa...or-3x00-t44387
                      That might have answers to the mounts?
                      And seriously, just run the LX9 on the DOHC code... Just change the VE and spark...
                      • #41
                        if by VE you mean MAF tables, he may not even have to do that. but spark will likely need attention.
                        • #42
                          I am really curious on how to mount the TCE crank trigger setup with the mounting of the W body mounts. Is it going to be like the spooky mount config where it's going to need to be really all out custom fabricated?
                          • #43
                            Got a pic of how it is setup in that W body?
                            • #44
                              • #45
                                Is that different than PCGUY's 96? That aluminum piece on the 3500 BTW isn't correct for W body.
