If one were to look into taking a 96GTP with the 32 valver and swap in a lX9, would the stock GTP harness be retained or would it be best to swap the harness? If the answer is swapping the harness, what harness would you use?
Also, what about the PCM, wouldn't you use the the 96 GP 3100 PCM so you can DHP tune it? Lastly, what about the crank trigger, will the 60*v6 crank trigger clear that lower subframe motor mount?
That is all. ...... for now.
