How about a '93 '727 pinout? I have one but it's not as clear as the ones you have been posting. I would like to make a simple guide one can print and go out to the car with
well, what from 93 uses a 7727 with the code mask you want?
I believe that is the first year of the 4l60-e since it has no TCC control yet has 2nd, 3rd and 4th control. Probably could use 4th gear for TCC? Also not sure what to do with the Camaro's secondary AIR relay (B3), A/C status (C2), or the 24x crank signal (C21).
The car needs to pass a visual and sniffer for inspection, so as much of the emissions needs to remain as possible, specially since it will now be MPFI.
I will upload what I have so far, take a look.
EDIT: and I'm trying to be productive, just need to get this figured out and tested for others to follow
1993 Lumina 3.1 ('9396 ECM). It's supposed to be the same as the '727, but just want to make sure since I picked up 2 '9396's and 2 '727's for the project.
Thanks!
OH, and does All Data do foreign cars?
they do, but i only have the disk for 82-02 GM cars... i might be able to find a foreign one, but it would take a while...
