THE OBD1.5 to OBD1 Conversion Thread
  • THE OBD1.5 to OBD1 Conversion Thread
    i'm waiting for the black PCM plug still, but this is how far i've gotten on the guide. it is fairly if not all the way complete. when i get the plug(shipment was rescheduled for today), i can further refine it if necessary.
    feel free to criticize or otherwise.
    its in .doc, but if you need it in some other form, contact me and i'll see what i can do.
    EDIT: DOC removed, latest version of the guide in this post. if it gets updated it will ALWAYS be here.
    EDIT: Newest version of Guide Date: 9/16/2009.
    EDIT: Added new starter pack to this post dated 12/21/09. a lot of little misc changes, notabley added a fuel economy guage to the DF ADX.
    It opens in open office, so linux folks should be ok.
      i would hope so, i made it in openoffice, i just saved it as a doc since its probably more accessible to everyone that way.
        Since you did it in OpenOffice, why didn't you just make it a PDF? Also, I'll probably end up making this an actual article, and link to a location to download the actual guide. I just skimmed through it really quick, but it looks pretty good so far. One thing you probably need to say is that people need to verify their pin-outs, as I am not 100% sure that all PCMs through the OBD1.5 years had the same pinouts. They probably do, but I would rather there be a disclaimer telling them to verify...
          I have L body diagrams so I can compare when it's done and let you know.
            i mentioned that i guaranteed it for the monte but for the rest i'll have to run through them..
              Most excellent writeup.
                still needs a little tweaking, and i may just add the repinnning tables for every variant if needed. one question though: 94-95 V6 F-Bodies use the same PCM as the rest of us obd1.5 3100 cars, but will the tranny controls work for them too? i don't know enough about the 4l60e. i imagine it would work fine with a t5 though...
                  I tried to do it this way, and I gave up and went OBDII, granted that may not be as easy for you, but it was easier for me. I couldn't get sensors to read properly so the car wouldn't run right, I used sockets from a old 95 computer and soldered on the 3 plugs needed for a OBD1 ecm from a Buick IIRC because it had 4t60e controls... I spent a few months on it and then just gave up.
                  Hope your turnout is better.
                    The buick A-body is an oddball, hopefully this one will have more luck since it doesn't use the weird MAF only setup. This one is more common.
                      Maf wasn't my issue... I had problems with my coolant temp sensor grounds, my cam position sensor and so on... I was receiving a maf signal IIRC, just all those other f-up's such as the coolant sensor not reading right (-40) made it run super rich for no reason... and I couldn't figure out the other grounds to get the cam position sensor to work. I had problems with adapting the ECM to the harness that was there, why I don't know, and hopefully your adapter works better, but I just didn't have luck with something like that.
                        Right, didn't say the MAF was your issue, but I'm saying that A-Body setup was so different than all other GM vehicles that who knows what wacky grounds and shared 5v references they had going on. Hell it had a MAF built into the TB or something weird like that too. The UIM was unique too IIRC in how it bolted to the TB.
                          luckily i don't have to deal with a cam sensor, just the 3X crank sensor...
                          trust me, if there is a way to do it, i will find out how...
                            how many fans do L and N Bodies have? according to my alldata, theres only 1 relay. are there 2 fans that run on the 1 relay or is there just 1 fan?
                            i'm asking because i thought of a very interesting way to show how differently the W, L, and N Bodies are pinned. those are the only obd1.5 3100s, right?
                            Details to come soon...
                              here it is: my big ass interchange of repinning.... or something like that.
                              i'll work it into my complete guide in a little bit.
                              there are some very small changes between the pinnings for the W, N, and L bodies. they should be fairly easy to see though.
                              and as a disclaimer: assuming L and N bodies are grounded EXACTLY the same way as a W, then this section is complete. i don't have a N or L to inspect to verify, and alldata doesn't have a whole lot of info about it either. so take it for what its worth.
                              EDIT: and i don't think i can do any automatic F-Bodies because from what i can infer, they have a pressure control solenoid for line pressure, something this PCM has no way of controlling, however, if someone was interested in running this PCM on their manual car, i can try and make it happen...
                              ANOTHER EDIT: i checked the pinouts for a 95 Monte Carlo, 95 Beretta, and a 95 Grand Am. i don't really see GM changing the pinouts from 94 to 95, but i'll check anyway(meant for brad, i thought you were talking about something else earlier)
                              FINAL EDIT: XLS removed, it was pointless since i have all of the different bodylines pinouts in the guide, post 1
