Hey Robert, have you drove the car any since doing this? Have you drove it and it shifted on it's own at all? Or just rolled it back and forth in 1st and Rev? I need to tune as my injectors are getting up to 92% duty cycle and I'm running lean at WOT, and also my AE needs upping with the bigger TB. So I'm starting to look close at this now and read into it.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
interestingly enough, i just logged it moving back and forth today... picking up lots of knock though. not sure if my tensioner is fooling the knock sensor when it decides to smack timing cover or if it was because of how loudly a lifter was ticking due to me not running it in a while...
my initial estimation on fuel requirements were very close, no more than 10% change needed to get the BLM/INT +-2.
spark is whats worrying me ATM: i see the log it going from 12-24* sitting still with no throttle. not sure why its adding and subtracting 12* for no reason.... may have to take a look at my underspeed/overspeed tables and see if its making that much change...
may have the money to insure it/put tires on it/replace tensioner/(HOPEFULLY)replace the fenders and door.... soon. i'll know for sure if i managed to pick up employment at my former shop... making GM parts
Two 10mmm bolts and 2 7mm bolts on the MEMCAL cover.
MEMCAL cover... What's that? lol. I forgot to put the one back on in the 91 (and probably the 92) and ran it that way for a year or two. I know it's stupid to do but by the time I remembered I didn't have the cover on I had already driven it through the winter snow and spring rain showers. Then again, mine mounts cover side down (at an angle) and it also isn't right there at the cowl where water could get in. It's also protected from splashes by the huge earlier style coolant tank.
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
If you just want to solder the female obd1.5 plugs to the wires of the 9396 then that's just 3 parts for ~34 before shipping though right?
You got that knock figured out, might want to post what the issue was here.
Ahh, that knock. not sure which it was, if it was the tensioner, the lifter or because i have a VERY different spark table compared to then. or maybe its because i'm using the 3.4 knock filter? who knows? its gone now.
