l67 Injectors
  • #16
    I didn't imply that I want to SELL;--
    At least I knew in a sense what I have if I did thread it.
    I am back
    Mechanical/Service Technican
    • #17
      You didn't come right out in and say it, but it's there.... /done
      __________________________________________________ _______
      SOLD SOLD SOLD Valve Covers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
      • #18
        -The fuel injector on the left is out of a 1995 Pontiac Bonneville SSEI supercharged 3800 series 1 engine!
        -The fuel injector on the right is out of a 1999 Pontiac Grand Prix GTP supercharged 3800 series 2 engine!
        • #19
          The injector on the left is the 99 GTP injector. I done work on a 00 GTP and they look identical. The injector on the right is the Bonneville one.
          • #20
            These images are pulled directly from rockauto.
            This injector is listed under a 99 GTP.
            Now this injector is listed under a 95 Bonneville SSE.
            Raise your right hand!!!! WRONG!!!!!!!
            • #21
              I think someone got owned.
              • #22
                No way dude!
                Those are backwards!!
                I pulled all 18 of mine out of the cars myself!!
                A 95 Bonneville was being drug into the junkyard when I was there!
                I went right over and took the supercharger, lower intake manifold and the fuel injectors out of it!
                That same day I also took the injectors out of GTP!
                2 weeks later, at another junkyard.... I took the injectors out of a 94 Bonneville SSEI!
                That same day I then took 3 injectors from a 96 GTP!
                Thats why I have 12 from a series I and 6 from a series II and 3 from a 3.4 DOHC!!
                Look at the picture!!
                • #23
                  No way dude!
                  Top ones are out of a Series II, 2nd row is Series I and bottom are 3.4L DOHC. Go look on rockauto for your self. The newer injectors are skinner than the old ones. Older ones are fatter. Are you sure someone didn't swap a Series II into one of the Bonnevilles? Those top ones are def. from a Series II engine. Maybe they had the wrong year listed on the car?
                  • #24
                    They didnt have the wrong listing on the car, I looked at the sticker in the doorjam of all 4 cars, as I do with any car that I take parts off of at the junkyard!!
                    Maybe that website is wrong... could that be possible?? People make mistake!!
                    I mean, honestly.... It just seems to be too big of a coincidence that I would pull out 6 of the top 1s from a 95 SSEI Bonneville and then the other 6 top 1s from a 94 SSEI Bonneville.... THEN, the 6 middle 1s from a black 99 GTP!!
                    Why would someone switch all those injectors around in a junkyard, and not even take them or anything??
                    Is there anyway for me to test out my injectors to see what the flow rate is??
                    Because "IF" you are correct then that would mean that I have 12 36#s laying around and only 6 28#s...
                    • #25
                      Look fr a PN on the side of the injector, and we can look it up from there.
                      But I agree... All the older injectors I have ever seen are the short and fat ones, and the newer injectors are long and skinny.
                      • #26
                        • #27
                          I also have another set of #28 that just needs the plastic pintle caps. $27 SHIPPED in the US (Canadian folks PM for shipping) .
                          For that price, you could buy the injectors, buy some pintle caps, then snap them on and still save $$$!
                          • #28
                            The #s on the side of the white injectors are:
                            E 060, 661, 0280155737
                            The #s on the side of the black injecrtors are:
                            927, 468, 280150934
                            • #29
                              Annnnd?
                              • #30
                                Annnd.... thats the part #s from the injectors!!
