MP 90 FWD project, first mock-up
  • MP 90 FWD project, first mock-up
    As much as I hated to tear into my DD, I could not wait any longer to do some test fittings. The MP 62 will go back on tomorrow
    Battery relocation is needed for this, and t-stat housing modification.
    Here's what some raw castings look like, and a modded t-stat housing. The outlet at left front was sanded to fine grit and bead-blasted.
    I'm watching with sheer excitement...
      wow nice who made your castings ? going hoodless ? i have all kinds of questions but i will sit back and watch
        This looks awesome. I can't wait to see more.
        Tim
        325 whp 350 lb-ft
          Can't wait to see what comes of this.
          Castings look amazing!
          2000 Grand Am GT
          2011 Chevy Impala
            Thanks, you won't believe what's holding up this project now. The test car is going into litigation lol
            The tranny build went so bad, I'm having to take the guy to court. I've almost got my sense of humor back, but don't have the car.
            Anyway, as shown in the mock-up, the blower housing comes within 1/8th inch of the hood where the hood bracing crosses over it. I believe the bracing can be notched out a bit for enough clearance. As it sits in the pics, the SC outlet rests on the brass fitting atop the t-stat housing. I did not try the modded housing because I did not want to drain the coolant yet again.
            With this SC outlet, I was trying to get close enough to the upper intake to allow a 90 degree elbow to reach it, and get good flow. With a shorter SC outlet, you might get better clearance and piping options for intercooling, but I was concerned that flow would be affected. So the outlet design is negotiable.
            The SC inlet I am very pleased with. I tried to make it as universal as possible, starting with a 68mm opening and enough room to tap threads for the stock size throttle body mounts and bracket. I'm not sure yet, but I think the LX5 adapter plate will fit. I'm hoping it can also serve as a mounting point for the blower case. It also closely matches the MP90s 45 degree angle inlet contour, so I anticipate very good flow with it. It is much thicker than it needs to be, allowing for porting or thinning down the outer surface if desired. It can also fit the MP112.
            These are obviously not "investment castings," try to price some and you'll know why . However, if you have the patience to make a pattern and can locate a good sand casting foundry, these are pretty affordable. Just how affordable I won't say at this time. A local machine shop charges $10.00 per unit to put a flat mounting surface on them.
            As far as weight, this MP90 unit is about 31 lbs without the castings, about the same as the MP62 with its casting installed. The MP90 inlet is 4.25 lbs, and the outlet 2 5/8 lbs. This extra weight will make the mounting system a great challenge, and is probably the most critical step in the process.
              Nice! i like it.
              Shane "RedZMonte"
              1992 Lumina Z34-VIRGIN (RIP)
              1992 L67 Lumina Z34 (SOLD)
              1990 Turbo Grand Prix (SOLD)
                Just might work
                Long story short, car was held hostage out in a lot for about 10 months, but at least I got it back.
                  This works I want a set of those castings.
                    Samesies!!
                      Um add a third to that list... As well as info on the snout you made. Hell I'd take a "kit" if you made one.
                      Its either this route for me, OR I'm going centrifugal. Just right now I don't know what to do and I'm a bit short on funds to just throw at it... Maybe next winter.
                        S/C on a stick! i wanna see it! DO IT... DO IT!
                        Shane "RedZMonte"
                          prototype driveshaft mount
                          Haha, 'tain't no snout, that's a 2-piece drive w/extended driveshaft. Here it is held in mid-air with a two point mount on the driveshaft. This type of system can allow lateral movement to align the pulley, and clamp into position.
                          Side of engine and/or top of transmission should be able to secure to case, possibly make use of the outlet's mounting holes. Indentation on the putty shows where the hood brace almost contacts the blower case.
                            Shortened the black UIM adapter, test fitted a 90* coupler, needs some more trimming, should seal ok (damn, that coupler looks big!). TB cable will need to go under or outside inlet, not exactly what I wanted. Next I need to take a guess at a belt size, and determine the final blower position.The pass. side lower radiator hose is too close to the belt, and it was already cut for the original kit. I'll get a new one and work with it. (I hate draining coolant). Then, hopefully I can come up with a case mounting
                            And btw, the pulley is 3 inch, somebody do the math and predict what the boost will be
                              Ditto. Coolant and diff lube are my least favorite fluids.
