Fiero buildup - Cavalier replacement...
  • #31
    7730 ? or that other ECM ?
    • #32
      Regular 7730
      '86 Fiero, 3500, 4-speed
      • #33
        What are you running now?
        • #34
          a1 with a 7730.
          Car developped a dead miss at high throttle over 4K RPM. Like it hits a rev limiter... I'll have to check the ign. module and grounds and that stuff. was running soo well the other day.
          I think my fuel pump just took a crap.
          I'll fill the tank with fresh gas and see what it does.
          • #35
            a1 with a 7730.
            Don't fill it all the way... even with a fiero's tiny tank they get heavy!
            • #36
              My car only has 30 useable litres before the pump gets LOUD. Even though the tank holds 40. Kinda annoying.
              • #37
                OK, the high load miss went away after a bottle of lucas inj. cleaner... ? lol. I'll see how long the fix lasts.
                And on a good note, the 2000RPM surge was just a throttle stop screw issue. It was allowing too much air in at idle, adjusted that and now the car runs very nice.
                Dyno soon I hope.
                • #38
                  The miss is still there. I'm pretty sure its fuel pres. related.
                  so...
                  decided to order new fuel pump. 5CA400 was 71$ from fuel pump.net, but then the 5CA400HP 255LHP was only 121$ so I went with that one instead.
                  it'll work better with the Precision billet58mm I just got...
                  • #39
                    Have a wideband in the car yet? I need to get one in my fiero too. When it was on the dyno it was going lean at high rpms.
                    • #40
                      looks like I won't have the only turbo 3500 fiero...
                      • #41
                        I finally figured out the high RPM miss...
                        My cat is broken / falling apart.
                        stupid waste of space cats. I'm going to hollow it out there later tonight... haha.
                        • #42
                          were you running a stock fiero cat still!?
                          • #43
                            nah a 3" catco. Pieces of honeycomb are flying out the tailpipe, haha.
                            • #44
                              Oh an nope, no wideband in the car yet...
                              • #45
                                lol... the poor honda behind you... lol
