you can get a t25/40 I think from ATP turbo. Uses the stock exh side but a larger intake side so you can spin it slower and have cooler charge, but push more cfm for more power.
just go to www.ATPturbo.com and take a look at there turbos. THey hve stuff that will bolt to the stock crossover and give more airflow.
not sure if this will work. Its the 25/40R and goes for $1k. Will bolt to stock crossover butmight need to make a new downpipe as its a 5 bolt discharge and I dont' know what stock is.
Dual Ball Bearing GT25/40-R Turbo assembly with specified ar. T25 style inlet flange with 5 bolt style exit. Large 60- 1 style compressor housing with 4.00" inlet and 2.50" outlet. Very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 450HP.
