MIlzy Stage 2 3500 heads
  • MIlzy Stage 2 3500 heads
    OK i have been hearing all these horror stories bout milzy. Well before I started hearing all this I had ordered a set of Stage 2 3500 heads from him. Well it took a while to get them, something like 2 months and costed about $1400. Well here are my pics and I would like some judgement calls on these cause I am not sure what I am looking for or at in regards to the quality of the porting and polishing. http://schmieding.tripod.com/my_phot...m/sspx0140?i=8
    do these look as bad i person as they do on camera?
      thats pretty much how they look in person.
        I would not spend over 1000 for port/polish work on any V6 heads let a lone 1400 for something of that quality.
            Ask for a refund.
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
              are those bad??
              93 Firebird 3.4
                Originally posted by tkoforpresident View Post
                are those bad??
                they're not good...
                especially for the amount they cost.
                  x2
                  i've ported 3 sets of 3500 heads now, none of them look like that and i only charged each person $200 (they brought me their heads).
                  I would ask for a refund, Mike is a nice guy and i hope he takes care of you.
                    Well the $1400 covered the assembled heads. what also hurt was I didnt have a set of cores to send. As for the refund goes what do i do just call him up and tell him I am not satified with his work.
                      WOW! That's all
                      I charge $350 for the labor on porting itself, then if the heads need a rebuild/machine work (or core charge), that's added in.
                        Did you even get assembly lube?
                          no assembly lube with purchase.
                            this is the run down of what came in my purchase.
                            Stage 2 - Full port and polish, port-matching the intake runners, D-shaping/re-angling of exhaust ports, significant bowl work, correcting the short side radius, polished cc-matched combustion chambers
                            Race Valve Job (9-angle Intake, radiused Exhaust)
                            CC-matched combustion chambers
                            stainless steel swirl-polished under-cut valves in OEM diameter
                            Comp Cams valve springs (128lbs at install height), Comp Cams retainers, and Comp Cams keepers
                            bronze valve guide liners
                            new Viton valve seals
                            assembled and toleranced
                            clearanced for safe lifts up to .560"
                            milling up to .020 free of charge
                              WHOOSH!!!
                              i'll restate it:
                              did you even get assembly lube?
