Stage 2 - Full port and polish, port-matching the intake runners, D-shaping/re-angling of exhaust ports, significant bowl work, correcting the short side radius, polished cc-matched combustion chambers
Race Valve Job (9-angle Intake, radiused Exhaust) CC-matched combustion chambers
stainless steel swirl-polished under-cut valves in OEM diameter
Comp Cams valve springs (128lbs at install height), Comp Cams retainers, and Comp Cams keepers
bronze valve guide liners
new Viton valve seals
assembled and toleranced
clearanced for safe lifts up to .560"
milling up to .020 free of charge
How does one match something that is so irregular?
Half of the stuff listed there sounds like smoke and mirrors. You simply can't do it, or can't for that price, and it certainly doesn't look like it's done that thoroughly from the quality of the work. They look like crap. I'd say he got ripped off.
'97 Grand Prix GT 3800 (sold)
Gotta love boost!
1500 and my machinest would weld and reshape the ports, do a 5 angle valve job, and flow bench them. You could have probably done a better job yourself for the cost of a porting kit from summit racing.
98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
