What cam
  • #16
    i deffenetly would, i don't have any marks on the heads but i only put 800 miles on it.
    .040" is the standard, the rods stretch at higher RPM's so you need a decent buffer area there.
    How much did you pistons stick up over the top of the block?
    • #17
      I measured .019 popup on the 3500.
      From PG-1..
      • #18
        Originally posted by Badassoldspower View Post
        So what is the most affordable solution to tuning?
        The cheapest would be a used Powrtuner that would run you about $300. But I don't know if your Cutlass would be covered and DHP has stopped supporting the Powrtuner program.
        Your local OBDII moderator
        2000 Grand Am GT w/ WOT parts
        • #19
          Im pretty sure they supported the 97 cutlass so it is just a matter of finding a used DHP tuner.
          • #20
            any other like not so user friendly software that is readily avaliable?
            • #21
              HPT or Powrtuner are the only options for OBDII.
              • #22
                That is not all that great to hear at this point, Im not even supported under HPT either
