LS6 Valve Springs?
  • LS6 Valve Springs?
    There are two types offered by Ligenfelter on eBay......The .552 lift (orange striped) and the .580 lift(yellow) The only other difference I can see is the 90 vs 92 pounds closed and the 294 vs 295 pound open......any reason other than lift that the yellows are 3 times the money as the striped?
    I doubt i will be putting in a cam with a lift greater than .552 for my boosted app with 3500 heads so I am thinking the cheaper stripped ones....thoughts?
    Also as far as the retainers and locks. Are the LS6 retainers(#10166344) the same ones that we have stock and if they are not are they better?
    I dont want to spend 90.00 on retainers and locks from Comp unless everyone thinks they are worth it compared to the LS6 stock ones. Thanks
    I just put in the orange striped ones. You need the LS shims, and you will need different seals, but you can use your stock keepers.
      LS1 have 1.8 install height...
        And.........this is bad....good......wrong.....right?
        They are LS6 springs not LS1 or is that redundant?
        Thanks
          I means you have to subtract .100 from their max spring spec. We know you can run LS6 springs over .500 lift though.
            I have a set of 3400 heads with LS6 Yellows installed sitting on the shelf, i'll see if i can get coil bind and max lift from them tonight...
              I will be using the 1991 Cavi seals....I guess my question really is....is the orange stripes as good as the yellows and
              Do the LS6 retainers fit better than the stockers. The stockers have some wiggle room. The comps suposedly do not, I am questionin weather the LS6 retainers fit better than the stockers.
                Everyone around here is using the yellow, not sure where the orange come from.... At least I haven't seen any 60* builds using orange...
                  The orange and green stripes are the ones before the yellows...still LS6 and are just a tad different than the yellows.
                  I am asking opinions on the retainers.......has anyone used the stock LS6 retainers and if so do they fit tighter than the 60*V6 stockers...or is the only other alternative the 90.00 Comp set with Comp Locks........?
                    they are the same as ours stock vs stock.
                      If i remember right the LS1/6 retainers are the same as the V6 ones, they have like 1mm of play but so do the LSx spring seats.
                      *edit, Dammit Ben!
                        pwned! haha. I have a box of LS retainers here:P
                          I agree that they are the same as I have a set of LS yellows with the stock retainers and my 3500 retainers fit them the same way with the same amout of movement. If I lay them side by side you cannot tell the difference between them. I'm using the stock 3500 retainers on the Comp Cams 26986 springs that I got from Ben. Real nice springs that fit over the stock 3500 oil seals/seats that came with the headgasket set. No need to buy any other seats or cavi seals. Just like it should be, no problem-no hassle.
                            Not trying to hijack this thread but Ben, whats with your avitar? Are you into martial arts? I have been in the arts for 30 years. 5th Dan TKD,1st Dan Kuk Sool Won. Muay Thai 8yrs. and Taiji for 10 yrs. I like to mix the hard for fighting and the soft for health.
                              That is a very good question and I would love to answer that on the behalf of Ben. That fighter that you see in Ben's avatar is a key character in the television series called Dragonball Z. The name of the fighter in Ben's avatar is Burter. The fighter in my avatar is from the same television series and his name is Kakarot.
                              To sum up this brief description of who these fighters are, Kakarot beats the living tar out of burter.
                              /discussion.
                              02 GTP - 90* > Failboat
                              www.blackbombshell95.com
