Well I guess its about time I show everybody what Ive been doing lately. Ive posted this on other forums and I was thinking why the fuck didnt I post this here!
Heres the engine from a 2004 pontiac grand am... with 8,000miles!
Started tearing into it, and look at how clean this thing is! The timing chain looked good as well!
And heres the intakes I got back from Ben!
Heres a comparison between the small port 3100 engine and the p&p'ed large port
Got the heads off and heres the block:
Heads... new enough that the paint is still there
Heads stock cam and timing chain and sproket
stock cam
1211 grind
LS6 springs and comp camps retainers
My whole goal for this project was to wake up this 3400 a little bit, but still have it run good/decent on the OBD1.5. Ive done alot of research about cams on OBD1.5... and according to the general sensus, a good performance cam that would work good was around 206 duration and 472 lift... this cam is very close with 205.2/205.4 duration and 478/480 lift.
And currently, the intakes and other odds and ends are at powdercoating. Im getting the intakes in silver, 3400SFI in body color, and a few brackets in silver and black.
Also as your reading this, I dropped off the heads to have the springs and retainers installed so i should have them back later today when i go into work.
stock cam
1211 grind
