So you're looking for the part with the purple paper on top?
Cali 2.8l air cleaner parts
Originally posted by Syndicated View PostSo you're looking for the part with the purple paper on top?
I can promise you 10000000% that vacuum motor with the purple paper on it is NOT for your EGR. It's the thermactor valve. It diverts hot air from AROUND the exhaust manifold via that shiny steel shroud and Tin foil tube.
The EGR valve is bolted to the intake manifold and is barely visible under the air cleaner in the 1 o'clock position when looking from the front, in relation to the carb.
Originally posted by Syndicated View PostI can promise you 10000000% that vacuum motor with the purple paper on it is NOT for your EGR. It's the thermactor valve. It diverts hot air from AROUND the exhaust manifold via that shiny steel shroud and Tin foil tube.
The flap is controlled by the thermactor, which is a vacuum motor.
It has nothing to do with emmisions.
There is a linkage rod from the thermactor to this flap.
I believe vacuum is supplied to the motor by a thermostatic valve, which is mounted on the bottom of the air cleaner. I think mine says "AC Delco" and is in the 3 o'clock position from the carb.
Mine stopped working a loooong time ago and I haven't noticed.
