Think I should clean the oil pump screen?
  • Think I should clean the oil pump screen?
    HI I'm new here and I was thinking of droping the oil pain to clean up the inside of the pain and the oil pump screen. The car has 163,000 miles. The engine has a little knock only at cold start up. I changed the valve cover gaskets and the distributer gaskets and their was no varnish or sludge on any thing the enigne still looked new. I use moble 1 synthetic oil and AC Delco filters. Should I clean the pump and pain or just leave it alone. I have the 3.1L V6 LHO.
    Just leave it unless there is cause for concern. If you have good pressure I wouldn't bother. If you need something to do on the weekend it wouldn't hurt.
      I doubt it's your screen. It's more likely to be a combination of wear on your main bearings and your oil pump. If you drop the pan, might as well change that pump. But I think "just leave it" is good advice.
        Thanks I will just leave it alone. But If any one else has the 3.1L engine have you ever taken off the oil fill cap with the enigne running? Because when I did this on my car with the engine at operating temp their was no oil coming out the tops of my push rods at idle but it sprays out if I rev the engine to around 2,000 rpms. I use 10W30 moble one synthetic and AC delco filters.
          You could always buy an oil pressure gauge and see if your pressure is low.
          The rule of thumb is 10psi for every 1000rpm. On edit you could also try a thicker oil. What weight are you running now?
            Thats completely normal. I use Red Line 5W30 Synthetic and Delco filters and it works beautifully for me.
            I just got back from a camping trip and on the highway I pulled an 8% grade for 17kms. I had the bed fully loaded with camping gear me, my girlfriend and the dog in the cab. I had it pegged wide open in 4th gear 3500 RPM doing about 120~130K up the entire hill. The oil did get rather hot because the pressure at idle was lower than normal but as things cooled off the pressure was back up. Needless to say I am impressed with the old iron dog.
              Thanks I will just leave the engine alone. I don't race the car so I guess the engine will be okay if I take care of it.
                If you have the pan off and a new pump is cheap enough I would put a new pump ,screen and pan gasket but thats me.If you don't have a problem at all with the car then leave it alone..if it isn't broke don't fix it..sound familiar?.
                  Oh no....if you have easy access to the pan...Go Fer It....if your Cam Sproket has the Nylon OverLay on it.
                  I've seen at least one 3.8 engine shell-out cause that Cam Sproket shredded bits of its covering...Oil Screen got plugged, bypass kicked in, and on oil filter, and that beautiful motor bit the dust.
                  I couldn't rotate the motor, so I had to drop the cradle out on this one:
                    On those digital gauges (88 Beretta), how much is one horizontal bar equal to?
                      Engine Oil Pressure
                      Oil Pressure should be 25-40psi at 1000rpm and 45-55psi at 2000rpm. Minimum oil pressure should be 15psi at 1000rpm and 30psi at 2000rpm. If this is not the case clearances betwen the bearings and crankshaft journals are excessive. Pressure should be checked only when the engine is warmed-up.
                      Note - I just evaluated my oil pump...and it was by-passing...which drops oil pressure readings...rods/mains were in good shape for 150,000 mile motor.
                        Man that article is way off on oil pressure. At idle if you have 7 to 10 PSI your fine At 2000 PSI 20 to 30 is still golden and 45 PSI is all you need at 5000. While the pressures you quoted are fine going any higher is simply wasting power and putting heat into the oil which are 2 things you don't want to be doing. Engines don't need enormous amounts of pressure. They just need a constant non failing supply of oil. The oil wedge that sets up and keeps the journals off the bearings is set up purely by the rotation of the parts them selves and does not rely on oil pressure at all. Things that do rely on oil pressure are the hydraulic lifters. The oil pressure in the system only needs to be adequate to force required volume of oil through the passages in the engine. The volume needs to be sufficient to compensate for the bleed off rate caused by the clearances in the motor. Hence the more clearance (wear) on the motor the more volume needed (or pressure drop occurs). Now the stock pump on the 660 is a very adequate size. Which is why it boggles me when people put high volume pumps on these motors. The stock pressure on these motors is high from factory, I'm guessing most cars are like that so they will survive when they get old.
                        If I had a way to do so I would put an adjustable regulator on the oil pump and keep it at roughly 10PSI per 1000RPM. But I guess I can't do that unless I score a good deal on a dry sup pump and build a pan.
                          Man that article is way off on oil pressure..
                          Today...I just finished up putting back together my 88 Beretta...with 2.8...long story short...Rods/Mains are good for 150,000 mile motor...but Oil Pump was by-passing..and dropping oil pressure down to 12 psi hot idle.
                          Installed new pump...but since I have 10-40w in it...these results aren't fair.
                          80 degree outside air temp- Full 60 psi (measured) at cold idle..30 psi hot idle....I think the Oil Pump's bypass is controlling pressure at cold idle....2000 RPM hot...50 psi...but I think the Oil Pump is in by-pass mode.
                          I only drove it several miles, and parked it, but I'm going to put in 5-30 this Sunday...and compare.
                            At cold idle you may reach the pressure relief. But hot idle will not. If you are getting 30 PSI at idle thats a lot but still not near the 60 or 70 PSI the relief opens at.
                            The pressure of the old pump was in no way due to the pressure relief. The 12PSI was all you were getting because of the wear on the pump and perhaps the oil you were running. Along with the 150,000 miles of wear even though it may have been very little. But all in all 12PSI was good.
                            I think you are getting confused at what the pumps pressure relief does. All it will do it bleed off excess oil once you reach the limit of the spring. It may be around 60 or 70 PSI. Only at that point will oil bleed off from the pump and return to the pan without being sent through the oiling system. One thing you have to remember about pumps is they DO NOT CREATE PRESSURE, They only create flow. It is the resistance to flow, caused in this case by the galleries and clearances in the motor, that create the pressure. So at low idle the pump turns slow and less flow is created which means there is not so much oil going through the system meaning less resistance and less pressure. At 5000RPM maximum flow is being created and still being forced through the same spaces so the resistance is higher and there for the pressure is higher. This pressure is then controlled at a maximum by the pressure relief system which will open and bleed off oil back to the sump reducing pressure in the system.
                            Also 5W30 and 10W30 are the exact same Viscosity at 200*F. You will only notice a pressure difference when cold. If you want you could run 0W30. Most cars these days are running 0W now in order to reduce cold operating fuel consumption because it is thinner when cold which robs less power.
                              I have run some tests on this new stock Melling Pump installed. On my digital dash, oil pressure is given in number of bars seen...I determined via shop-air hook direct to oil-sender that
                              5 Bars = 30 psi...and
                              9 Bars = 60 psi
                              Hot Idle:
                              a. 10-40 - 3 Bars
                              b. 5w-30 - 2 Bars
                              Cold Idle
                              a. 10-40 - 9 Bars
                              b. 5w-30 - 8 Bars (but just after oil change with warm engine)
                              After 2100 RPM, 5w-30 (Quaker) stays pegged at 7 bars (42 + psi)
                              10-40 has similar results...
                              Conclusions -
                              A. With Cold Idle, bypass is kicking in
                              B. With Hot Idle, bypass is not kicking in
                              C. After 2100 RPM (Hot), by-pass is kicking in.
                              D. By-pass spring tension is temperature dependent; as temp increases, your by-pass pressure decreases.
                              Rod - 0.0015 clearance
                              Thanks for the tidbit...I was thinking about using 10W30 next oil change...but 5W30 should work just fine.
