Originally posted by betterthanyou
View Post
>45-55psi at 2000rpm
This is within the range I am seeing (*45*) at 2100 RPM HOT...but I feel this new Milling pump's bypass circuit is kicking in...since even if you take it up to 4,000+ RPM...it's still *45* psi.
>Engines don't need enormous amounts of pressure.
True...when enough bearing surface area exists...
My 855 Cumins (N14) maxes out at 45 psi Hot at 2100 RPM; that's the way they designed it to save fuel in 1994...at idle, they allow 10 psi on the low side....at 1,000 RPM, its up to 30 psi.
Gas engines, if enough bearing surface area exists, don't need much for lower horsepower applications. My in-law's 1 ton 4x4 has around 45 psi hot at idle...if I recall the conversation correctly
