Can I reuse fuel injector o-rings?
  • Can I reuse fuel injector o-rings?
    I'm installing some fuel injectors that have been removed from an engine for about 2 months. Can I reuse the o-rings or do I need to get new ones?
    Reusable
    Cammed 3400 --> 224whp 210wtq
    Cammed 3500 --> ???
    1 of 5 3500 J-Bodies
      Great Thanks!
        Just get new ones, they are cheap and install so much easier. The old ones are probably swollen.
          or at least lube them with something.
            I reuse them all the time, but always keep spares and check them after install by turning the car on to allow the system to pressurize, then checking for leaks.
            I lube mine up with petroleum jelly each time they're reinserted, and it's usually (Not always) fine.
              Is there a way to clean feul injectors? like once you have them out, instead of just dumping random crap in the gas tank?
                http://60degreev6.com/showthread.php?t=25017
