Injector Cleaning
    • 13508
    Injector Cleaning
    This section brought to you by
    A fuel injector is nothing but an electronically controlled valve. It is supplied with pressurized fuel by the fuel pump in your car, and it is capable of opening and closing many times per second. When the injector is energized, an electromagnet moves a plunger that opens the valve, allowing the pressurized fuel to squirt out through a tiny nozzle. The nozzle is designed to atomize the fuel -- to make as fine a mist as possible so that it can burn easily.
    Here is a cross-sectional view of a typical fuel injector:
    Here is an actual report from Witchhunter injector services courtesy of Marty (RacerX11).
  • Rhedalert
    Dr. Feelgood
    • 1574
    '96-99 3400 sfi "red band" injectors
    Brian
    3400 SFI V6, 4T60e
