2.8 hp
  • 2.8 hp
    Hi
    does anyone knows how much HP and TQ a 2.8L can handle
    thanks
    RE: 2.8 hp
    Depending on year make and model, and the most important part the trans. Most trannys made in the year of the 2.8 can just handle what the 3.1L MFI can, when GM introduced the 3.1 one they had to update the trans, in 1993 most 3.1L equipped models came with the 4t60-E all 1991-94 DOHC models got it except rare manual equipped makes, where most pre-92's base models got the 4t60. The 4t60-E can handle up-to 245hp, the parts for the 4t60-E where standardized in mid 1993.
    A 2.8L MFI can be over bored to a 3.1L, and the ECM can be reprogrammed. As far as that the 3.1 is a 2.8 clone.
    I am back
    Mechanical/Service Technican
      RE: 2.8 hp
      The 2.8 wasn't bored to a 3.1 it was STROKED!!! I think the most you could increase a 2.8 by boring is to just shy of 3.0L.
      Brian
      3400 SFI V6, 4T60e
        RE: 2.8 hp
        in theory, you can (and it has been done) bore a 2.8l to 3.620. this is what ari engines does to build their stroker 3.4l in a 2.8/3.1l block. it however leaves the cylender walls paper thin.
        basicly, the 3.1l is just a different crank and pistons (pin height is different) than a 2.8l. as for how much power it can take, well, how much money do you have??? there is a simple formula for how much power an engine can have. it goes as follows:
        money = horsepower
        basicly, tell us more what you have and are planning to do with it
          RE: 2.8 hp
          it is posible to produce 100hp per liter
          thanks
            RE: 2.8 hp
            Not without making spending a TON of money (~$25k-$35k), and making it a full-on high-rpm race engine, which wouldn't be much fun on the street. More realistically, 200HP is pushing it for a 2.8 street engine without boost.
            Marty
            '99 Z-28 - Weekend Driver
            '84 X-11 - Time and Money Pit
            Quote of the week:
            Originally posted by Aaron
              RE: 2.8 hp
              280hp isnt to far out there. what year is the motor (is it aluminum head or iron head) and is it in a fwd or rwd application???
              if your willing to build it up a little bit (forged pistons, stainless valves, 3x00 top end if its a fwd) and put a modderate amount of boost to it (15psi or so) it would be able to have 280hp.
                RE: 2.8 hp
                280 hp wont' cost $25k!!
                WTF are you smoking>? Put the crack pipe down.
                Forged pistons, some head work and a Gt30R will get the job done EASILY no less.
                280 hp on forced induction is not hard on this motor.
                $5-6k tops.
                  RE: 2.8 hp
                  BTW my 2.8 engine is making more then 200 crankhp and its got plenty left. Stock GM 17 year old internals.
                    RE: 2.8 hp
                    I was referring to making 280HP NA on a 2.8 costing that much. Everybody knows you can make that power easily with boost....so put YOUR crack pipe down. He never asked about boost. I stand by my cost estimate if you want to make it NA.
                    Marty
                    Quote of the week:
                      Re: RE: 2.8 hp
                      Without nitrous? Got a dyno sheet to show you engine putting down that power NA?
                      Marty
                      Quote of the week:
                        200hp n/a is possible, and there is likely a lot left to be had. but as far as cost effectivness, boost would be the best way. if you can afford expensive gas, the early s-10 pistons will yeild just under 12:1 with aluminum heads. using the newer 3400 heads and intake will have to be on your list, and a good cam as well. the crane 272 would probably reach the tagret HP, but late in the rpm's, so you'll have to re-gear or just wait for it to rev up for the fun to come. and you'd have to have a set of headers. then there is still the question of "what is this going into?" that would be a major factor, as in the fwd transmisions you have imited gear options, if any, and rwd is pretty wide. and there are also complications with using fwd stuff in the rwd platforms, like aluminum heads and a distibutor dont really fit together on the topside.
                          The original question was how much a 2.8 can handle. Not make. It can handle well over 200 is what I am saying(been proven by a lot of people) but even so your 25k engine is still way too high.
                          Stock crank will work- Free
                          forged rods - $600
                          forged pistons - $600
                          oil pump - $100
                          Machine work on bottom end - Lets say $1k
                          All the head work including porting and machineing and parts- lets make it high and say $2k
                          Camshaft and lifters pushrods - $500
                          Carb and intake mani - $2k lets say for arguments sake.
                          gaskets - $200
                          Still way under 25k
                          Gm made 270 hp n/a with these motors back in the 80's and it didnt' cost $25k to do it.
                          And explain to me why anyone would want to try and do it n/a for "$25k" when you can do it for much less money? N/A is such an old school way of doing things. Forced induction is the now and the future.
                          to answer the original question again and keep this thread on track, a stock 2.8 can handle 250+ hp all day on a stock bottom end with proper tuning.
                            Well I will stick with my antique n/a fully built 3400
                            http://www.v6z24.com/registry/ginobeats/
                            http://www.v6z24.com/registry/ginobeats/2
                              Well, the 3.1 is capable of 450+ hp, thats turbo of course, so i would assume mabye 400+ hp
                              1990 Turbo Grand Prix - 80,000 Miles
                              1990 Pontiac 6000 LE 3.1 - 234,500 miles
                              1991 Olds Cutlass Ciera 3.3 - 337,600 miles
