Hows this happens with only 36k miles?
  • #31
    old cam on the right new cam on the left
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    • #32
      Finally after two months
      ITS ALIVE!! few more things to take care of and i can get it off the stands and get pics/vids but itll have to wait till monday
      Daily Driver
      • #33
        If I am not mistaken, it looks like a different cam position sensor setup? If you have a code for the sensor, you will need to get a 94-99 sensor.
        • #34
          no code for the sensor..BTW the car is a 94/96 so it already has a 94-99 cam sensor
          Daily Driver
          • #35
            Ben when you gonna learn all the sensors work with any cam... I've never seen one throw a code.
            I had a 01 cam and block running with a 94 sensor. And now I have a milzy cam running on a 05 sensor on my 97 ecm... I've tried a bunch and it still works.
            • #36
              I guess the ECM just goes off a square wave from the sensor and doesn't care if it's high voltage for the long duration, then low for the short, or high for the short duration and low for the long.... I guess if you were to graph them they would be opposite but its just looking at pulses I guess. Hard to picture in your head but I guess thats the case.
              • #37
                AKA leading edge, all the edges start in the same spot so they all spike at the same location, duration afterwards doesnt matter ist just where that initial spike is that matters.
                • #38
                  damn cyl 6 and cyl one are miss firing horrably..6 being the worst..ive changed everything on the top so now its done to wiring and compression check..
                  very very stressful
                  Daily Driver
                  • #39
                    You'll find it sooner or later... Hopefully it's not bad though.
                    • #40
                      How did your cam bearings look when you had the motor apart? I had the cam dowel break off on me because of a spun cam bearing.
                      • #41
                        cam bearing looked fine as did the cam other then the pin
                        tear down #3 to begin soon..cyl 6 has no compression at all..testing this weekend to figure out why
                        Daily Driver
                        • #42
                          Dang dude
                          I can't help ya but best of luck.
                          SpudFiles
                          Theopia
                          Enjoy life online.
                          • #43
                            I would like to take another trip to disney...
                            Got any cash left over from the swap, Maybe I'll come down and help you out... ROFL
                            Keep me updated. I don't want to blame Ben, but I almost want to see it be a problem with the head/heads... that would save you lots of time vs it being a problem with the piston or cylinder.
                            Oh did you ever check compression on cylinder 1?
                            • #44
                              Thanks but I hope you are wrong.
                              • #45
                                A head or valve issue is a lot easier to fix than a lower end problem.
                                Could just be a stuck open valve from something stupid... who knows. That kinda chit happens with the race car sometimes. Rather annoying if you ask me.
