installing the 3500 crank trigger wheel
  • #16
    just to make sure i understand this correctly, on my 3500 swap i will need the timing cover and dampener from a 00+ 3400 for the 24x ring/sensor then the external 7x sensor also, correct?
    • #17
      I think the 3500 cover has holes for the 24x sensor. 24x is only needed if your car is 94 or newer that uses the 24x stock.
      • #18
        so just the dampener needs to be swaped and the sensor installed? im going to be using a 98obd2 ecu on my swap.
