ADJ Vacuum Modulator 4T60e
  • ADJ Vacuum Modulator 4T60e
    Auto idiots (autozone) part # MV303, $12.99.
    I installed mine, gave it 4 turns in as instructed, we'll see tuesday if it helps. Wow its small compared to the old one!
    ADJ? Mine is Pioneer brand.
    If your old modulator was in good shape then it won't help a ton with WOT. Just part throttle shifts. But mine I guess was worn as it shifts better at WOT. I guess the spring is fresher in the new modulator.
      oh, please tell me ADJ meant adjustable, not the brand....
      i need an excuse for the facepalm poster...
        the adjustable modulator will help with shift firmness at all throttle positions. just depends on how far you turn the screw in.
        Andy
        fastest 1/8: 10.19@ 67.17
        fastest 1/4: 16.16@ 82.70
          Keep turning till you hear the pump rattle, then back off a turn... LOL
          Actually I'm serious. At least I was able to do that with my 95... The 96 I pay more attention to my crusing trans temps since higher pressure will raise the temp of the fluid.
            as long as you don't run a max psi all the time, it's ok. it's best if you can achieve what you want with the lowest pump pressure. less strain on the pump and pump shaft.
            Andy
              I have a bit of a supercharger sound that comes from the trans at low speeds sometimes when you are next to a wall. I'm guessing it's the pump. But not rolling you don't hear it...
                Yes it means adjustable!!!! Isaac! You walked right into this one bro!
                    And the grand finale:
                      hey pocket, stay out of ohio man! 'cause when isaac goes hunting you i dont want to be in the cross-fire! lol
                        Well hopefully he understands I'm just playing around like Robert, lol. If not, at least my car can out run his
                          The trans in my Moante does this. I've heard '97+ gtps do this. I thought it was just a 4T65-E HD thing.
                          Lorenzo
                            ADJ = Awful DJ. Adj = adjustable... Get it right!!
                            Pocket, out run me? Sounds like a challenge!
                            Lorenzo: Glad to hear about the Manatee, so I know I'm not alone!
                              I'm always up for a friendly race
