3500 LX9 in a 1999 Grand Am 3400
  • #16
    Hmm, I guess depending on how they changed the tone ring on the cam it might be larger in diameter or something and need a shorter cam sensor... Odd... Did any of the wire colors match up?
    • #17
      I did this all three weeks ago and when it didn't start I walked away from it for a while but if I remember right only one color matched, red I think. Then on one the one was blue while the other green, then one black vs brown I think. But anyway it was not a situtation where I could have used the 3.4 one. Thanks I'll let you kniw when I get the adapter on and running if I have more issues.
      • #18
        I think the 3500 one is longer because it doesn't have the wiring coming out of it, but rather a plug for the wiring harness. I suspect that the part that actually goes into the block is the same length. The crank sensor, on the other hand, the 3400 sensor IS about 3/4" longer than the 3500.
        • #19
          I have a 3400 cam sensor, i'll put it in my spare 3500 block and see if it fits tonight...
          • #20
            Exactly how it worked for me. I didn't take pictures but it was identical from the O-ring down. Getting it out of the block was a chore but it fit without any issue.
            • #21
              Only way I've removed mine is yanking on the wires. Other ways will break the tab. I've re-used my original cam sensor every time I've had the LIM, which was 3 or 4 times lol
              • #22
                the 3400 sensor fits the 3500 just fine. they are the same length.
                • #23
                  idk if u did it already but u also need the crank position sensor from the 3400 behind the dampaner and the 3400 dampaner
                  • #24
                    i'd move it back to 0 and work on the tune from there.. you are losing a ton of power having it in that position.
                    have not started tuning it yet, but I tryed it at 0 to day and the car is a dog now! lol going to try about 1/2 of what it was before and see how it works. It dose feel abit better in the low end but its not pulling as hard above 3500.
                    Preacherman any updates?
                    14.96@91.47 in the 1/4
                    9.63@74.36 in the 1/8th
                    • #25
                      are you sure it's at 0? there is a line on the sensor block that should line up with the 0 on the mount.. With mine the 2 small allen bolts line up perfect with it at 0.
                      can you take a pic of it?
