I need help, I've read most of the post and threads but I'm still stuck. I put a 06 Pontiac G6 3.5 in my 1999 Grand Am, Where the 3.4 died. Every thing is in and I used the 3.4 upper part of the intake to retain the TB and the throttle cable. I put the pick up and the dampner on from the 3.4. BUT the cam posistion sensor and the crank sensor in the block are different, the crank one has 3 wires and the old one only two. The old ones don't fit the 3.5 block. Now I've read the 7 vs 56 crank info and here is where I get stuck. It won't fire so do I need a later computer or what.
