Freescan ALDL too SLOW!!
  • Freescan ALDL too SLOW!!
    Okay, I made up a good (max232 chip) cable, so I'm good there. I'm using a 200mhz(?) laptop, which I think is plenty fast... I got the two of them to talk, and can change the idle rpm, look at stuff... But the problem is, that it seems like it takes 10 seconds for everything to update! Even my 160baud from my camaro updated like twice a second... I'm trying to figure out of my O2 sensor is going, so I need a quick refresh. I tried clicking on the "log data" button, but when I opened the file after it was done, it was blank! AAAAHHHHHHH! 2 questions: why is it so damn slow, and why isn't it logging? It also crashed twice! This software seems to be crap IMO, anybody else having this problem and/or any suggestions?
    Okay now, that's enough of that.
    You have to stop the data log or it will be empty once you close freescan. Also, did you try changing the ms freshrate rate? Default is 100.
    What os are you using? 98SE is pretty stable, 2K has to have the refesh set a little higher, XP didnt like it too much.
    What definition file are you using and what car/engine do you have?
      I believe I did stop the log before I exited... I'll try again to be sure. I changed the delay down to 10ms, and didn't notice much (if any) effect. I am using windows 2000. I am not using any definition file, but selecting the 3.2L pontiac engine from the pull down list (it says vin X is covered with this one). I have a 93 GTP/3.4L
        Use the 3.1 one, the 3.2 one sucks ass and doesn't capture it all. The 3.1 one works great. Set it to 50, and maybe try 100.
          ??? I don't think I have a 3.1 option on the menu?? I'll check. Will this solve my problem of it updating (the "dashboard" and the CSV log) every 1-3 seconds? I know for sure the "log ECU to file" doesn't work no matter what, and the CSV only works when I check the "interact mode".
            Yeah, the 3.2 file doesn't work for the 3.4 DOHC so I never use it. Use 410B, its the 3.1 file.
              Using the 410B file all I get is "Finding Start Header" over and over and over again. I think its an issue with my laptop, but I can get TTS Datamaster to work with my P4 Dell laptop, so I dunno.
                what year is your car?
                  89 chev beretta
                    That is why, freescan only works with 91-93/94 3.1s
                      freescan TOO SLOW for me to, 93 GP DOHC with a 94 3.1ECM and 93 FFP prom
                      \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
                      - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
                      - 160* T/stat - Dual 40 Series Flowmasters
                      - Hi-Flo Cat
                      15.2@95mph - GTECH P/B
                      http://home.rgv.rr.com/tjperformance/Cap0005.mpg
                        Well my engine is a 93, so I guess its time to update some software before I mess with it anymore.
                        Does freescan require the 91-93 MEMCAL or the ECM? Or both?
                        Memcal should be simple. Ecm will be a bit more expensive, but still possible.
                        On a side note, anyone know of a LOCAL chain type store that would solder my ZIF socket to a spare memcal? I'd rather not send it out to anyone and Im too chicken to try soldering it in there myself. Im fine with removing the stock eprom, but those 28 pins are pretty darn close. Would a TV repair shop or something be able to handle something like that for me? I cant think of a place that would definately do it.
                          Radio Shack would have done it.....BACK in the days. Now its a freakng phone place...LOL... oh...off subject...
                          Well yea they should be able to with a fair price. I should tell you Chris that the beretta ecms seem to change alot from year to year...even some chips and dirvers seem to differe. I have compred ecms to verrify. Those w-body ecms seem to stay the same though. Thats prob why we have problems. I will prob resort to making my own code.
                            With my previous beretta I was swapping ECM's and memcals like $2 whores and never really had a problem with how the car would run. The problems I ran into were with differences between US - Canadian ECM's and memcals. Originally my previous beretta was from Arizona so was in MPH. I wanted KM/H so I went about mix matching ECMs and memcals. At one point in time I had my speed limiter kicking in at 110 km/h. That really sucked. Even using Corsica ECM's from other years I never experienced any poor driveability. Maybe I was just lucky. I'll give a 91 3.1L auto ECM and memcal a try next chance I get. Shouldnt be too different and I'll still avoid the ABS and other added features. I have a 91+ interior anyway, might as well finish the swap.
                            Seriously think Radio Shack would be able to solder something like that for me? They seem like tools whenever Im in there. Getting the old Eprom out was easy. Just did that in like 3 minutes with a spare memcal. I might go buy a tiny soldering iron and give it a try on my own.
                              I think hes saying the TV place might =P
