Factory DOHC Parts
  • #31
    yes everything sold has been shipped.
    • #32
      Front Lower engine mount?
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
      • #33
        yup have like 6 jeje
        • #34
          wouldnt happen to have any OBD2 wireing harneses would you? everything to swap it over to a 92 with OBD1?
          and maybe a set of coil packs and ICM?
          1992 Oldsmobile Cutlass Supreme International
          3.4L DOHC Getrag HM-284
          1 of 85 Produced whith the manual tranny
          New addition: 1981 Dodge Power Ram W150 4x4
          6" lift, Dana 60/70, 35" County Terrain, 440c.u.i. 4bbl swap
          • #35
            If they are in good shape how much do you want for one??? Price shipped??
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
            • #36
              O also would you happen to have the plastic cover that covers the timing belt on the side.. the large cover shaped like a V.??
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
              • #37
                The only timing covers i have are broken.. The mount is pretty much perfect. Used but no signs of failing or cracking. We're having a gp meet this saturday at the tacobell/pizzahut parking lot in saintjohn on 41 at 7pm, if you come i wont charge you for it.
                • #38
                  do you have the bracket that the timing belt actuator bolts up to?? the cast aluminum one? Please let me know as soon as you can
                  Robert
                  New Rebuilt 3100
                  New Rebuilt 4T60-E
                  Exhaust
                  White
                  5 Speed Swapped
                  127,000
                  Spec Stage 3 Clutch
                  Emissions Deleted
                  • #39
                    Sorry for the LONG delay but yeah i have the part if you still need it. I also still have the motor mount.
                    I have a TON of dohc parts guys, If you need ANYTHING I probably have it.
                    • #40
                      Hello I am also looking for the tension accuator bracket if you have anymore?
                      • #41
                        For the timing belt?
                        • #42
                          the bracket on the front cover it has a tapered bushing for the tension accuator. I ended up snapping the corner off I seen someone else with this problem. I think you can remove the pulley and maybe two bolts to get at it.
                          Oh and if you have the accuator itself as well, how much would you charge for them?
                          heres a picture of the bracket in the same condition as mine
                          • #43
                            Yeah I have it. I have one from a 95 96 and 97 do you have a preference?
                            • #44
                              Well I have a 96 they are probably the same though now is this for the bracket or tensioner or do you have both? I would very much like the bracket overall.
                              Thanks
                              • #45
                                ok no problem shoot me a pm and we'll work out the payment and such
