Got some workspace...
  • #16
    Yall suck with your nice spaces to work on stuff. I've got an oversized 1 bay and someone only insulated half of it (haven't gotten around to finishing it). I epoxied the floor and added 8 4' shop lights in it wired in pairs, but the floor was poured in 1954 and it's obvious they used a 2x4 to "smooth" the floor ftl. I have just enough room to pull an engine with my hoist, but most of the time I play it safe and let it go up between rafters. Maybe I will dig out some pics of my junk...
    • #17
      John...so many naked walls ...I'm going to have to send you some of my larger oil-on-cavas work to help out...
      ...or maybe just few Girly-Cake Shot Calendars?
      • #18
        My sad hole :/
        These pics are at least a year outdated now... Since I have put a corner mica countertop in the corner where my speakers are, the engine hoist now sits between the counter top and the black jack and jack stands, my parts washer (the big blue thing beside my piece of junk toolbox) has moved to the other side of the compressor, on the opposite side of the bench beside the parts washer (beside where the front of the Jog is) now sits a 12 ton hydraulic press, and the gas bottles for my heat wrench have moved behind the trash can beside the press. I've also gotten a much larger collection of tools hanging on the wall and have started running out of room on the peg board :/
        • #19
          Just paint the walls themselves
          Man, your space is tidy for everything that's in there!
          • #20
            Thanks! But, that was then... I dare not venture out there with a camera right now I've actually got plans on going out there tomorrow to clean and organize since I have a good deal of time to wait for Phil (onefastv6) to get home before Ben and I head out to his place for an engine. I can't stand working in crowded areas... It tends to drive me up a wall and I tend to start getting mad and shoving stuff/throwing things, lol. It's probably the German and Irish in me I really want to finish the insulation and drywall, and paint the drywall gray since white would show grease too easy, and dark colors would absorb my light making it harder to see.
            • #21
              Got some cabinets up, and 1 floor cabinet. Flowbench will go on top of the base cabinets once I get things organized and setup out here
              • #22
                Captain... In your posted image, I just spied your air delivery PVC piping set-up and need a water bleed unit just like the one shown over your second work space bench...I cannot find anything that small where I am located right now, so if you get a minute...would you let me know what that item is and where you got it? I need one for my home Made EFI Cleaning Unit to bleed off the build up of h2O in the service line b4 it can contaminate the EFI Cleaning Fluid... Thanks in Advance!
                (John...Please forgive this minor thread-jack)
                --==Bob==--
                • #23
                  It was from a local welding supply shop and they discounted the last 2. I have a larger one from harbor freight just out of view and the smaller one is a regulator for the die grinder.
                  • #24
                    since everyone is posting their workspace pics...
                    this is mine.
                    • #25
                      Found a lift for $200 under my budget! Going to the Key's on Sunday B)
                      Couple had the lift under their 18' stilt house then moved. Now the wife wants to get it out of the storage unit lol. They didn't want to set it up outside and it get ruined
                      So, had to make some room, and went ahead and put the Bimmer in there to see actual workspace with customers cars inside...
                      • #26
                        Looking good man I need space like that around here, but I wouldn't be able to afford it. BTW, how much you paying for it?
                        • #27
                          With everyone showing off their workspaces, I figured I'd show off mine as well. Unfortunately, all of the car stuff is still at our other house...
                          BUT... Luckily, my wife needed my to go over to the other house last night to pick up some paint for a project she is working on at this house, so I took this opportunity to slowly start bringing engine parts over.
                          Too bad it'll still be a while before I get a chance to do anything with it.
                          • #28
                            Flow bench is in working condition...
                            Here's the calibration unit that has to be used everyday the bench is turned on (to zero out the barometer...
                            and here's what it will kinda look like when the head adapter is finished; ignore the values on the meter and laptop - major vac leaks with the acrylic tube and head resting on the top.
                            • #29
                              you guys and your fancy digital setups.. i prefer to stare at blue liquid
                              Nice!
                              • #30
                                That looks nice, man!
