Originally posted by bszopi
View Post
Got some workspace...
Really? I know I've seen 480v panels labeled, and some 208v panels labeled, but I know not all are labeled. I don't think we ever say anything either in our designs telling the contractor to label panels as such. Hmm... Unfortunately, you can't look at the manufacturer's label plate either, as all lower voltage panels are capable of 240v, regardless if they are run as 240v or 208v.-Brad-
We have to install lables telling the voltage and transformer connection, delta-delta or delta-wye or the inspectors will never sign off. You are right about the manufacturer's data plate will list both 208/240. We also have to lable the panels with arc flash data before we are done now.
Originally posted by dskopek View PostWe have to install lables telling the voltage and transformer connection, delta-delta or delta-wye or the inspectors will never sign off. You are right about the manufacturer's data plate will list both 208/240. We also have to lable the panels with arc flash data before we are done now.-Brad-
Originally posted by 60dgrzbelow0 View Posthttp://s557.photobucket.com/albums/s...iafilter=image
Okay... It has been a while since I looked at John's incredible shop for motivation... but owing to a recent windfall on getting a pile of lumber for free after doing some favours for a neighbor... I finally decided to start building some decent shelves in my garage so I can at LEAST walk from one end to the other and do more "Mecking" inside the garage than out. My envy of John's Shop has prompted me to create...
Der FrankenShelfer...
All I used to build it was some scrap lumber, a 7" Ryobi Chop saw w/ spread stand, a Screw Gun and a box of 3.5" & 1" deck screws. The materials and dimensions of this modular unit are as follows:
4- 2" X 4" X 7' Vertical Corner End Supports
2- 2" X 4" X 7' Center and Rear Verticals (Shelf Supports)
4- 1" X 6" X 7" Long Horizontals (Top and Bottom Runners)
8- 2" X 4" X 20" Short Bracing Horizontals (Front to Back)
12- 2" X 2" X 20" Under Shelf Supports (Staggered for both Shelf Sections)
18- 1" X 6" X 40" Flat Shelf Segments (Trimmed to Fit) Modular
18- 1" X 6" X 20" Shelf Bottom Braces
Box of 3.5" Deck Screws
Box of 1" Wood Screws
I decided to make the shelving modular so I can stack long tools and tall tool boxes should the need arise. The materials went together nicely and once built, proved very strong indeed. The unit is perfectly symmetrical and stands upright without the need of being bolted to a wall or the floor with anchors and lag bolts that would defeat the purpose of being able to hike the thing around in various places in the garage as needed. When the shelves are removed, it can be manoeuvred around the garage in various places as needed on flat dollies. The one foot space between the top of the shelf unit and the ceiling will be used to store the rest of the lumber I'm tripping over right now...
It's not a Big Deal in the scheme of things.... but few of us have a business necessity like John and Ben, nor the luxury of having a huge, multi-level garage for storage. And besides, in some cases...making the most of what someone else has thrown away can make the difference in allowing me the chance of having a few more square feet of space in my garage ...and I do like the idea of killing two or three birds with a single, problem solving stone whenever I get the chance!Last edited by 60dgrzbelow0; 11-15-2011, 12:26 PM.
