Wire that you can't solder to....
  • #16
    Originally posted by The Master View Post
    Try using sandpaper on the wire then flux to remove the dust.
    you've got the best username i've seen on this board.
    Flux pens are awesome BTW.. I use them all the time at work.
    • #17
      If regular solder wont work then try silver solder from a welding supply store. It does cost about $50 an ounce but will solder almost any 2 metals together.
      • #18
        Like I said I just took off the weather pack off the trouble wire and put on a single long normal wire. The location of the 3 wire CTS isn't as hot as the head sender so no worries there.
        Der Meister: I did try sanding it, but didn't try flux.
        Dave, you want me to mail you a section of the wire and you can test your skills and flux pen?
        • #19
          I've got like 4 CTS harnesses in the garage..
          • #20
            Yeah but are they the teflon coated mystery wire?
            • #21
              Home Depot sells it in three stick packages in the weldong section. Not all HD's have a welding section, though. You have to get it pretty hot, I would suggest MAPP gas or better.
              • #22
                It is either Copper constantan or Cupronickel.
                Of which both need to be brazed or at least 1200F
                I am back
                Mechanical/Service Technican
                • #23
                  hehehe yeah my soldering iron doesn't go that high. It's a silver looking wire all the way through. No copper color to it at all.
                  • #24
                    both alloys will look like silver especially copper con.
                    poor-solderablility requires brazing brazing:
                    Aluminum or alum-bronze
                    high-alloy steel
                    constantan or alloys greater than 15%
                    Fair:
                    Carbon-steel
                    zinc
                    Nickle pure
                    Easy:
                    Tin
                    Cadmium
                    Gold
                    Silver
                    Palladium
                    Rhodium
                    Good:
                    Copper
                    Bronze
                    Brass
                    Lead
                    Nickel-Silver
                    Beryllium-Copper
                    Usually the more difficult to solder a metal the higher the temp needs to be and also there are differnt solders that are not just the run of the mill lead or tin.
                    I am back
                    • #25
                      I got the sucker red-hot with a torch and solder melted and rolled right off it. Funny stuff.
                      • #26
                        I had this happen to me too, its not the CTS harness, its the wire that is on the single wire head SENSOR, not anything harness related, go find a single wire head sensor cut the wire off and I dare you to solder to it, it just wont work.
                        • #27
                          ^^^ Yup that's what it is.
                          I just wanted to use the connector on it. So what I did was re-pin the connector from the sensor wire, to a new wire and ran that wire down to the 3 wire CTS pig tail. So the stock single wire connector on the harness can still be disconnected (it's now up by the injector harness stuff by the alt). So the harnesses with the injectors and CTS wires can all be disconnected and left on the LIM now like stock.
                          • #28
                            I found one.. i'll try that tomorrow at work. lol
                            • #29
                              hhahaha Succeed you will not, Yoda says.
                              • #30
                                if my 120 watt iron won't do it, i have something gas powered that will...
