what bar is out map sensor
  • what bar is out map sensor
    I never really looked into out maf sensor and I was wondering what bar is our map sensor and what can we change with it besides northstar
    that question makes about no sense....
    depends on the vehicle, if it isn't factory boosted, its going to be a 1-bar map sensor. the factory boosted have 2-bar sensors.
    and what does the northstar have to do with anything?
      Yeah that really really doesn't make much sense.
        Originally posted by choppester View Post
        I never really looked into out map sensor and I was wondering what bar is our map sensor and what can we change with it besides northstar
        If you are actually referring to the DOHC; your map sensor is 1 bar. It only reads below atmospheric pressure or what would seem vacuum. 2 bar is for turbo or forced induction and can read 'vacuum' and pressure. Not to sure why you would want to switch the map to a different style as the delco fits and works just fine.
          Considering I posted it on dohc performance yes, I'm referring to dohc. And the reason asking is cause I threw on a 3 bar map sensor and tossed my old one because I'm the one that has a procharged dohc grand prix and I'm running alky control 3 stage. They sent me a 3 bar map sensor cause I'm running it under 3 different stages
            Under three different stages?? WTF does that mean? And why does 3 stages of alk have to do with a 3 bar MAP sensor? The BAR is how much PSI it can read/measure... not stages.
              i am also very confused as to what you are saying...
              and are you running MAF or MAP? which year is the vehicle?
                I put maf sensor and I have a dohc lq1 motor. The alcohol injection is on 3 different stages, but when I bought the kit they sent me a custom maf sensor thats a 3 bar. sorry for the confusion, that one night I had along day and I forgot I was talking about my lq1 and not my 3100 motor. I running a 3 bar maf sensor cause of the boost and the alcohol. the maf sensor helps us tune out the alky kit and procharger to match each other at the different boost levels from different rpms to get the most potential. anybody got me? so when I made the post I was drunk sorry you got me lol.
                  are MAFs rated in BAR, i thought it was a lb/hr or gm/sec or CFM rating?
                    MAP is rated in BAR (pressure), MAF is rated in grams/sec (mass).
                    Manifold Air Pressure
                    Mass Air Flow
                      thats what i was thinking... thanks isaac.
                      choppester, either you got ripped off, or don't know what you're talking about....
                        man lol. ok here they sent me a map sensor but I have a maf sensor, we are trying to change and thats the problem. Its easier to adjust the tuning with a map sensor with the alky kit so I'm wondering has anybody done this or what are the thoughts on this. I was told the alky kit would work with the maf sensor and to leave out the map sensor but the maf would need to be tuned
                          First of all, list your full setup, and what you are trying to do.
                            this is all on 95 lq1
                            light weight lifters
                            ported heads machined
                            procharger p1sc 7psi
                            ported intake upper/lower
                            ported exhaust manifolds, little port
                            msd coil packs
                            big intercooler
                            3inch exhaust no cat comes right off of the down pipe
                            magnecore wires and ect little stuff
                            this is whats going in this month and all done at the same time
                            alky control kit
                            tuning custom and expensive
                            walbro 255lph
                            adjustable fpr and custom fuel rail
                            removal of egr valve
                            shorted intake custom
                            and bigger throttle body (in the making at machine shop)
                            We are trying to get the alky control kit to put different pressure at the pump to match the rpms along with the fuel system, all trying to tune it out to its best running, AND YES I KNOW WHAT I'M TALKING ABOUT, I have an alky control kit that I installed at the shop on many gn's, this is an experiment car that we got pretty cheap awhile ago. I have never worked with a maf set up and installed alcohol injection. I was recommenced that it would be best to switch to a map setup instead for it to be easier tuning process with the alcohol injection but I've never heard of that being done with these motors and I don't know why somebody would want to do that much work.
                              ok, so now that we know its a 95, thats got a MAF from the factory, which runs on 2E.
                              SO now, what exact questions do you have...
